Where did you find that?Got a tear tag number… what’s that mean?
A tear tag means that your truck’s ECU has been programmed. It also means your truck is more or less built.Got a tear tag number… what’s that mean?
Oooh wow. In one day? Giddy up! Put that sucker on a truck to Montana!A tear tag means that your truck’s ECU has been programmed. It also means your truck is more or less built.
Yep! Ford isn’t great at everything but they do know how to roll a truck off an assembly line.Oooh wow. In one day? Giddy up! Put that sucker on a truck to Montana!
UserName | Location | Build Week | Blend Date | In Production Date | Built | Shipped | Estimated Arrival Date | Arrival Date | Trim | Battery |
asudan | MT | 11/7/2022 | 11/7/2022 | Lariat | ER | |||||
bewbie | NY | 11/7/2022 | 11/7/2022 | Lariat | ER | |||||
mh82ai3 | CO | 11/7/2022 | 11/9/2022 | 11/9/2022 | Lariat | ER | ||||
Trick | NJ | 11/7/2022 | 11/9/2022 |
Have you been watching the ford trackers to see if your truck incremented into the "IN PRODUCTION" stage?Had a week 11/7 build date, but the week has passed and I have not received an update. I’m guessing the tire shortage pushed things back a bit.
be sure to use the VIN on your window stick on the top right corner. Mine has changed since I originally found it using the backdoor method.Since all the online tools weren’t working for me, I decided to call the dealer to see if he was able to find any information. As of this morning, the only status he can see is that the truck is located in Dearborn MI on Ramp 59. He checked a shipping tool and it shows the truck has an estimated ship date of December 1st. Not much to work with here, but some info is better than none at all. He said he gets updates every Friday, so I’ll call back at the end of the week.
It's not a printed tag, we assume that it's a check-sum for the code loaded to your build configuration.Is there a way to view whats on the Tear Tag?
