Mike G
- First Name
- Mike
- Jan 6, 2022
- N. AL, USA
- 2022 F-150 Lightning, 2023(J1) Mach-E GT-PE
4 November and lots of updates this morning that were not there yesterday!
Looks like a selection of powertrain updates (PCM, BECM, SOBDM, SOBDMB, SOBDMC) and the ABS system and generic function #2 which I think may be the tailgate module but I'll have to double check on that.
So if you are doing these yourself you'd start with the PCM, and then the rest of the powertrain items would chain in sequence. Then the others in this list can be knocked off in any order.
I'll follow up with any observations afterward.
EDIT: All done and it was interesting. Above, I said to start with the PCM and it would chain all the rest of the powertrain items in sequence. Well here's how it went; I setup the powersupply and laptop and initially picked the PCM, no problem, very straightforward. What surprised me was that the ABS was next, I guess I had forgotten that the ABS is a powertrain module as well. So after the ABS was the SOBDMB, SOBDMC, SOBDM, BECM, and then this last one threw me and I wasn't expecting it, but the GFM2 was chained right along with the rest. So everything in today's list were all what Ford refers to as 'coordinated' updates that once you select one in the list you'll get a message like this one:
And then all you do is turn on and off the "Start" button on the dash and select "OK" on the laptop when it's time....and it steps you through everything in sequence.
Total time on the FDRS laptop from the very first vehicle 'network scan' to the final logoff was 28 minutes.
Stay safe and have a great weekend!
