The Lightning does not have the walk-away lock like the Mach-E. Hopefully it will be enabled in a future Sync update. In the meantime this is how I do it. NOTE: this is not for the faint of heart or home automation newbie. Also this only works on the iPhone. Sorry Android folks.
It requires that you have Alexa and that you have CarPlay enabled. You'll need to install Alexa and IFTTT apps on your phone. The basic process is that when you turn off your truck, CarPlay disconnects and this triggers a Siri Shortcut Automation. The automation calls an IFTTT applet that presses a virtual button (a "monkey") connected to Alexa. Alexa responds by sending the "lock truck" command to your truck. It all happens very fast, typically within 10 seconds once you turn off your truck and open the door.
See the attached PDF I wrote for step-by-step instructions. PLEASE do not attempt if all the lingo I just used is over your head!
Why did I do this? My old truck had a key and a fob so it became habit when getting out of the truck to take the key out of the ignition, press the lock button on the fob and put the fob in my pocket. With the Lightning and PAAK, I don't carry a fob and if I did it would be in my pocket the whole time. I've tried to remember to press the lock button in the truck or on the handle but I'm officially old and thus forgetful.
