LightningShow
At -15C the outdoor humidity is essentially zero. Turn on the fresh air intake to knock down the humidity in the cabin, then switch back to recirculate.
I just got my emporia set up this week but opposite application. I have it on the house main panel and my charger is on the garage/barn service. I’m loving it so far. I’ll probably get a second monitor for the barn eventually. I don’t charge at home much right now so it’s not that critical to monitor. I have finished space out there that gets used more in the summer. I’m more interested in monitoring that usage than the charging.This is the device I am using to monitor the branch circuit feeds to my FCSP.
https://shop.emporiaenergy.com/products/gen-2-emporia-vue-whole-home-energy-monitor
I'm using its main circuit monitoring clamps because of the large diameter of the conductors.
I am not using the smaller circuit monitoring clamps on my garages separate service, the other branch circuits are just for lighting, door lifts and the resistive space heater in my motorcycle workshop.
I mostly just use my heated seat and steering wheel but have to hit the max defrost button occasionally. My issue is when I hit it again my heat stays on with low fan, and I have to hit fan off everytime to turn the heat back off.Hi all,
Got delivery of my Platinum on Thursday. It's currently -15C here where I live.
I've noticed 2 things 1) not great range (fine, whatever), but 2) the climate control can't seem to keep the windows unfogged unless I have it on max defrost pretty much the whole time.
Anyone else noticed these issues? Perhaps I'm one of the farthest north owners at this point at 54 degrees
Thanks!
The OP is in Canada, fun fact, by default the user profile details are hidden, but can be shown by click the chevron below the name.I don't understand, are you talking about C or F, because if it's F, it's not even cold.
I find that if you use “Auto” settings, the heat, AC, and recirc all get turned on and off randomly. I stopped using Auto.Does E-Heat turn itself back on depending on outside temperature (59F), or interior temperature (?), much lower than setting desired (75F)? I could swear that I had turned off E-Heat the previous drive, but returning home, the E-Heat came back on by itself. I could not find any details on how the E-heat works in the manual.
New to the forum, was looking for similar problems with the climate control system on my 2023 lariat ER.Hi all,
Thanks!
