Jarratt
I've heard that the 12v battery gets run down and when that occurs, all manner of bad things happen. I assume that this does not occur if the truck is driven regularly. I've also assumed that when I'm charging at home with truck off that the 12 battery is recharged. Is this wrong?
I can anticipate weeklong periods in which the truck is neither driven or plugged in. Perhaps longer. Do I need to trickle charge in these circumstances? If so, is there battery powered trickle charger? Alternatively, can a conventional trickle charger be powered from the truck itself?
