F150 Lightning FORscan thread
biers
Thomas
SW Washington
eGolf
Ok. I basically started over and I got the lights to come back on, but the green DRL (parking lights) icon isn’t there anymore during the day. The brightness from what I can tell never changed either however those lights are pretty wimpy anyways so no even worth trying in my opinion.
keep me posted if # 1 you get a light bar and #2 how you programmed it. A guy on Facebook lightning group installed one, but he can’t get it to turn on. Says there is no power to the plug that already exists beyond the grille. Someone mentioned it will need to be “code added” not adjusted on forscan, since ours is a pro….
only dealer can do it but probably wouldn’t
Curious if you or @BennyTheBeaver were able to get the lighter to cooperate.
bewbie
NYC
Is there a way to make all of the windows one-click auto up down?
BennyTheBeaver
I have a lightbar, I haven't even tried to tackle it yet for a few reasons.
1. I'm backed up on projects due to poor weather and needing to work on the truck outside
2. Family/work has come first
3. The Pro grill's black lightbar piece is actually connected to the grill. I have to dremel off that black insert in order to leave a space for the lightbar. I don't want to do that until I know the lightbar mod works.
If I don't get to it in the next 2 months I'll probably just sell the lightbar on eBay. I originally didn't like the look of the black strip on the Pro, it had slowly started to grow on me.
For anyone looking to do this project, another idea I had (aside from Forscan) has possibly splitting the wires from the 2 DRL's into the lightbar.
There is not. The back doors lack the switches - they need the dual click to do it from within the truck.
It could be done from a remote or touchscreen if they chose because you can tell the computer to do anything you want.
Blochead21
PA
Black 22 XLT 311pkg
Does anyone know a way of enabling zone lighting through FORscan? Looks like the 2023 Pro has this already enabled but my 22 is missing it.
Sorry, i've been busy and without my truck some days so I haven't been able to respond. I can enable it in the as built sections, but it doesnt turn on once shown in the truck. If someone can send me a vin with a base Pro or XLT with zone lighting I can look through the as built codes better to compare.
Ford F-150 Lightning F150 Lightning FORscan thread Screenshot 2023-02-03 102633
Ford F-150 Lightning F150 Lightning FORscan thread 94F2DD1C-89AB-4BEB-82CF-A866C6C484F6
Ford F-150 Lightning F150 Lightning FORscan thread EBCEA060-4B79-458D-8459-67074C0CF70B
biers
Thomas
SW Washington
eGolf
Photon
Oklahoma
2022 Model S Plaid, 2018 Ford Raptor
Got glare free working tonight. Thanks all for helping with the forscan and testing!
Used the values from OP post, cycle each time I write to the module and double check each module before moving into next. I did have to turn my lights back onto automatic after writing all the code.
Whole process was pretty easy, but I’m also not a forscan newbie, had a 2018 Raptor that I changed quite a bit.
phenem
Zach
Central PA
22 F150 Lightning Lariat
Do you happen to have the ford part numbers for the sensor and the wire harness they include?
The rain sensor is the easy part. The harness is custom made by them and runs from the sensor to the clock spring / SCCM, so it’s not a factory part or harness and without some knowledge of the connector types would be hard to reproduce.
vsansal
Volkan
Arlington,VA
F150 Lightning Pro, Tesla Model Y Performance
Thank you. I was able to enable the menu option but mine is also not working either.
Jeffgtx
Ca
22 lightning
update on adding rain sensing wipers to Lariat SR.
I have only added the sensor on the windshield and changed the 4 lines mentioned earlier in this thread.
I did NOT change stalks or add any wiring.
Today it rained and I left the stalk in the off position which is the same as the A position in the new stalk and it never wiped the window. however, when i moved it up one spot to the single drip icon, it started wiping and then once the rain stopped, the wipers stopped.
so you do not need to change the stalk to get it to work. yay.
biers
Thomas
SW Washington
eGolf
Correct I don't see it, attached what i have and circled the factory connector
Ford F-150 Lightning F150 Lightning FORscan thread Screen Shot 2023-02-04 at 10.11.41 PM
Decided to take a second look and pulled the whole cover off. My 22 Pro does have the wire there, it was just tucked up there nicely. $40 auto wipers, here we come!
Blochead21
PA
Black 22 XLT 311pkg
Is this with or without the BCM line being modified?
Also can you confirm the rain sensor PN? And how that cover comes off?
Jeffgtx
Ca
22 lightning
its with all four changes i mention in my earlier post. so if one of those is BCM, then yes.
Add rain sensor:
7D0-09-04 x3xx-xxxx-xx—
726-39-02. xxxx-xxxx-01—
720-02-02. xx8x-xx—
724-02-01 xxxx-xC4x- —
part was
LU5Z-17D547-B
i cannot remember if it got substituted after my order for a newer part.
as i recall you just pull the cover down and it eventually unclips.
Blochead21
PA
Black 22 XLT 311pkg
Add rain sensor:
720-02-02. xx8x-xx—
part was
LU5Z-17D547-B
You guys are talking about this small clip with the green/blue/black wires for the rain sensor correct?
Ford F-150 Lightning F150 Lightning FORscan thread 6D25A7E7-BD6A-4388-A03D-C82BD2FC34BF
Ford F-150 Lightning F150 Lightning FORscan thread B312CF0F-422B-4668-96E0-78474D4DE119
Jeffgtx
Ca
22 lightning
believe so. there is a three prong wiring connector up there sitting in a clip connected to nothing.
