Pod
2023 AMB Lightning XLT SR
Hilarious, I was all ready to say Ford left it off mine and then…
went and looked. It’s there
silly me
now can we get that on a shirt?
brewski
GA
2023 F150L Platinum
Yes
Does that stubby antenna receive signal just as well as the oem antenna? Also, which stubby did you go with?
Thanks.
Go to the hardware store of your choice and get a 1/4-20 x 1/2" screw, it'll be about 50 cents.
I got a black rounded top hex.
I don't listen to FM much, but when I do, it works.
I installed the Lighting blue raised letters on the tailgate. Love the look! After seeing them I ordered the charge port door set from the same seller on Etsy.
Now you need to ditch that ugly dealer license frame ;) . I used a black rubber one for a clean look (post 980). I have the same decal on SQ. SQ is a little less black than AMB so you notice the black decal more but still a good look. I also ordered a custom plate that was black.
MJDore
SE Michigan
2023 Lightning Lariat ER
Finance
I’ve been looking at these. Which seller did you order from?
I also ordered from MotoUnway. Note you will have to choose Custom for $51 and specify in comments that you want reflective black with Lightning blue outline.
Streek
DJ
Ford F150 Lightning
I totally agree.
The last upgrade I'll do will be the AMP powered running boards. They're out of stock right now.
queuewho
Western PA
F150 Lightning Lariat SR
Painted the front grille and added the led emblem.
Where did you find the emblem from? Does the hue of the light match as well in person as it does in your picture? This is the best looking one I've seen, I've hesitated to order one because it always seems like the emblem LEDs are a lot cooler than the light bar.
Streek
DJ
Ford F150 Lightning
The emblem was purchased/installed by Chino Hills Ford. And the front grille was painted by Kustom Autobody in Montclair California.
Bob
Dripping Springs, TX
2023 F-150 Lightning Lariat, 2013 3.5 Altima SL
Reliability Engineer - PWR
silly me
LoL same here, Just look down on my truck from my home office window and saw it there.
