They hooked FDRS up to the truck to see that cell, that means the data is in the truck computers and a code was set. My guess is that code is what is causing Ford to reach out to customers to proactively get this fix done, the codes get uploaded to the cloud/Ford. The sheer number we've already seen is what is concerning for no more trucks than are on the road.Thanks for sharing. I’m curious if all ford certified dealerships will have this equipment to test out our batteries. I’m sure they will have to. Would love to see battery degradation at 50k miles. Even better if ford made service mode like teslas have now
That overhead comes with a lot of costs. I know Ford operates old school, but truly they would have been better off in large metro areas like DFW and even more rural areas designating EV repair sites. Let them all sell, let them all do minor work, but the investing in and repairing batteries. Train and give a lot of experience to 5 to 7 employees, then focus on 2 or 3 dealers in a large metro area so that they can make these repairs in a day. Stock 5 to 10 battery modules and cooling plates and make the repairs at one or two per day.Even though there is a LOT of overhead in the module system, the fact that they can be replaced is great.
I'm not sure why they didn't build the cooling into the module. He didn't say if they have to drain all of the coolant and replace, but I would assume so.
I could be wrong, but if I remember correctly, neither the bed nor cab have to come off. The entire battery housing simply drops down from below.So, if I'm guessing right, the whole body has to be removed from the chassis to do this job, right?
I can't disagree with what you say at all - shouldn't have a waste, but I don't think you'll see this kind of bad cell from Tesla, and truly I know SK and Ford don't want or think they'd see this many bad cells either. The key is they have to find the problem and get it solved.That is a great video, thanks for posting. I am not a fan of disposable parts, especially if they are expensive like the Tesla structural battery. Too much lost when a single cell can't be fixed or updated.
I assume this failed Lightning module will be disassembled at a specialty shop, that one pouch replaced, and that repaired module will be put to use in some way.
What rate of failure ?....
The rate of failure we are seeing is not a good sign for us.
Referring to the other threads here with owners that have been contacted and asked to have their trucks brought in for repair. I'm thinking it was approaching 100.What rate of failure ?
'22 or '23 ?
