Zansurf
- Dec 12, 2022
- Bishopville, MD
- 2017 Honda Ridgeline - Waiting for 2023 Lariat ER
Had to travel a moderate distance (approx 3 hours or 139 miles) from home for work. Charged to 100% the night before and should have had ample range. Cue a 25-30 mph headwind and 70 mph highways and I rolled into my destination with probably 25-30 miles of range left. Wrapped up my appointment and headed to the nearest EA charger. With all the reports of issues with these, I thought for sure the lack of connectivity was a charger problem. Spoke with customer service for EA and they saw no problems and that’s when I realized the red ring and some sort of charging fault error and a warning to get service soon. I tried other chargers and even relocated to another station. No dice, still throwing the red ring. Didn’t get the service soon but one other time. Ford wanted to charge $1k to get a tow home (warranty tow covers only the closest dealer typically up to 35 miles). I was not stoked at this point. Luckily I noticed I had just enough range to get to a dealer. Got there and they let me plug into their level 1 chargers and low and behold, no issues. Called my dealer and Ford corporate. They helped me the best they could but ultimately the answer led to a hotel star waiting for the slow charge to get me enough range to get home. Fast forward, I get home and plug in to the charge station pro. No issues! Seems to be something specific to DC fast charging? Hoping someone here might have insights but I do have an appointment at the local dealer tomorrow. I am worried they won’t be able to recreate my issue and send me on my way with the uncertainty that I may just get stuck anytime I’m far enough from home to require a stop at a charger.
MODERATOR
MODERATOR
So we have a resolution and it’s not nearly as exciting as one would think. Apparently there is an actuating pin in the charge port that only gets deployed for L3 DCFC. The pin is easily broken if you don’t unlock the charging handle properly at DCFC and all future DCFC is disabled. They are replacing the actuator. There is some TSB for this so apparently it’s not an uncommon issue.
