It displays the current charge rate, which is not available when it's done charging. It would be trivial to give us the average charge rate for the session, and yes I'm aware we can calculate it ourselves. It's just nice when we it's provided.
Energy added / Time charging = avg charge rate
Really wish we knew how/if they round or truncate. Longer/bigger charges will be more accurate than smaller ones (unless you have your own means to measure energy outside of Ford's devices) @Ford Motor Company would it kill you to provide at least 1 decimal place?
NOTE: Don't use time plugged in, if you don't unplug immediately then that time will be longer and give you a bad number.
Ekiehn
Eric
2023 F-150 Lightning Latiat, 2008 Ford Explorer, 2006 Ford Escape Hybrid
I got the update for Android when it first hit and the estimates charging is awlful..awful... charged from 10% to 95% last night estimated it would take 15 hours... actually took around 6.5....
Eastbaylightning
Antz Tony
Walnut Creek, California
F150 Lightning Pro
Just got the update. Estimated charging finish time was just off a little bit by 6.5 hours, not bad... ?
SmokingtheMeats
PA
2010 F-150
Tech
I’m having the same issue. It’s 7:50 pm and my charging time says it’ll be completed an hour ago while at 67%.
worst part is I just plugged it in.
Ford F-150 Lightning FordPass 4.27.0 update IMG_2892
PA Lightning
Tbone
PA
Lightning Pro
The 4.2.4 update on my Pro did the same thing. Estimated charging time seemed accurate before that update.
COrocket
F-150
Same - app update 4.27 completely broke the estimated completion time. It thinks I’m going to be able to go from 54% to 80% in an hour using a 6kW mobile cord ?
Ford F-150 Lightning FordPass 4.27.0 update IMG_1586
Brentt
Brent
2023 Lightning and Four Teslas
I got the download while away on a trip and noticed ford pass wouldn’t connect. I tried pulling #32 fuse, reloading the app, and disconnecting the neg terminal with no luck. I left it set for a couple hours and it went into deep sleep mode. When I returned I had to start it manually. It’s currently working but showing less range at 90% than before
Departure time, route scheduling has a bug, the arrival time is not being computed correctly, my trip is projected to be about 1 hour 23 minutes (accurately), leaving at 8:30, I anticipate arrival around 9:53 not 5:53 am
Ford F-150 Lightning FordPass 4.27.0 update 1684670546760
Good morning- I can look into this for you. Feel free to send over a private message with your VIN and dealership information at your earliest convenience.
Unless my dealer has application developers in the accounting office, I don't think they are going to be much help, this is a APP issue, truck is fine.
Looks like same -4 hour offset bug that’s in the charging completion time calculation.
Lytning
Georgia
" When I returned I had to start it manually. "
Is there a hand-crank in the frunk for this, or did you push it off to start? ?
Brentt
Brent
LOL, That’s what the app said!
Brentt
Brent
So much for Ford Pass working. It crapped out again this morning.
Ford Motor Company
Official Ford Account
F-150 Lightning
Hello! Send us a private message with your VIN and the name and location of your local Ford dealer. I’d be happy to see what I can do to assist with this charge concern. Thanks!
GingerBear85
2023 F-150 Lightning Lariat ER - Stone Metallic
Construction
Has anyone else noticed that when AC charging with the Ford Charge Station Pro or other AC level 2 chargers the app no longer shows the charge rate in addition to the other bugs with this recent update? Running FordPass 4.27.0
