You may have only used 17% of your battery, but there are charging losses to take into consideration if you're trying to figure out the cost to recharge your truck.![]()
If it takes 17% to charge back to 80% why can't I simply use that % change times the total battery size to calculate energy consumed? Is 17% of 131kWh = 22.27 kWh added correct or not?
I know you say you don't want a different charger, but the Emporia EVSE will accomplish what you're trying to do.
