MickeyAO
Mickey
San Antonio Tx
  • Switched all cameras to be able to be used at speed.
Wait, WHAT? You are able to turn ON the front camera at any speed? Please share this information!
UpWithFilm
Ohio
'22 Kia Niro Ev, '23 Avalanche Lightning XLT
Well, now that you mention it, I haven't actually tried to use them since I made the change. I followed the "easy change" instructions off another board and everything went through without error, so I just assumed that it worked.
I'll test it today at lunch and report back.
I finally got around to making some software updates to my '23 XLT via Forscan and did the following:
  • I tied the bed lights I installed a few months ago into my Zone Lighting and enabled the physical on/off button.
  • Changed my temp blinkers from 3 to 5.
  • Added universal window control (roll front windows up or down with key fob).
  • Turned on the glare free/matrix LED headlight feature.
Once you check your cameras at speed, go into the Drive Mode menu and see if you still have your option for "One Pedal Drive".
UpWithFilm
Ohio
I stand corrected. They don't seem to be working yet. I'll try again here in the next day or so.
UpWithFilm
Ohio
I do. Why wouldn't I? Is there an issue with that?
I may have been one of the few to use the "As Built" code to turn on cameras at speed last year. I made that change along with a few of the others. My "one pedal drive" option disappeared. Finally just a few weeks back I decided to go troubleshooting. I found the option to turn One Pedal On, when I did and lifted the covers to see what byte/number it changed, it was one that I had changed to turn on Cameras at speed. This led me to believe they could be incompatible on the Lightning.
LUXMAN
F150 Lightning PRO and XLT
Pilot
UpWithFilm
Ohio
I designed and 3D printed a MagSafe charger to replace the useless coin holder in my XLT.
This is a rough draft to test the fit, final version will print later today. Now I just need to figure out how to run the cable to the USBC port in the armrest or splice it into some wiring behind it.
Ford F-150 Lightning πŸ™‹β€β™‚οΈ What Did You Do To Your Lightning Today? IMG_0603
invertedspear
AZ, USA
lightningcalcs.pages.dev
Can't wait to see your final product and purchase it on etsy
Ford Motor Company
Official Ford Account
Ford
F-150
Very cool! 😎 Thank you for sharing and for being part of the Ford family!
jerock
Jerry
Kansas
Have you tried this mount? I’d be interest if it interferes with the eye detection camera. It does look like a great phone mount.
