Lightning Rod
- Nov 27, 2022
- North Coast
- 2023 Ford Lightning Lariat ER
- Occupation
- CNC PROGRAMMER/MACHINIST
Somebody did a few days ago. From what I read and heard, its not that easy of a trail and if it was, it wouldn't be much of a challenging course if every truck made it through without being challenged. Watching one video of tire slippage doesn't mean much.Did anyone post this hilarity yet, lol!!!
The article mentions the Cybertruck perhaps has no locking rear diff? They said it looked typical of open diffs. Could be a large differentiator for 4wd.Eesh. I hope Tesla has enough time to fix their offroad issues cause the Lightning is embarassing it here.
https://www.thedrive.com/news/ford-...-up-obstacle-where-tesla-cybertruck-struggled
Well if the Cybertruck really does have a tri-motor setup with two motors in the rear like the Hummer EV, then yeah it definitely doesn't have a locking rear diff which honestly makes all the difference in the world. One of my favorite features of the Lightning is that it has a mechanically locking rear diff. All the extra power from an extra motor in the rear of the cybertruck is useless if the two rear wheels can't work together.The article mentions the Cybertruck perhaps has no locking rear diff? They said it looked typical of open diffs. Could be a large differentiator for 4wd.
If it has two motors on the same axle it doesn't need a locking diff -- 2 motors is better than a locking diff. The Rivian has 4 motors which is even better.Well if the Cybertruck really does have a tri-motor setup with two motors in the rear like the Hummer EV, then yeah it definitely doesn't have a locking rear diff which honestly makes all the difference in the world. One of my favorite features of the Lightning is that it has a mechanically locking rear diff. All the extra power from an extra motor in the rear of the cybertruck is useless if the two rear wheels can't work together.
This is patently false and has been disproven in countless traction tests. Two motors on the same "axle" (I put that in quotes because there is no axle and no mechanical connection between both wheels) means both motors are mechanically independent of each other and the only way they can turn together is through software control. In principle, this seems like a pretty straightforward implementation. But in practice it is almost always inferior to a mechanical locking linkage.If it has two motors on the same axle it doesn't need a locking diff -- 2 motors is better than a locking diff. The Rivian has 4 motors which is even better.
But if the 2 motor version doesn't have at least a locking rear it could be an issue depending on how good their traction control braking works.
Rivian is not a good example because it's known for its weird/unexplainable off-road power control tuning. And AFAIK it doesn't have virtual lockers which it totally should so you can tell the truck how you want it to behave in more detail than just selecting a drive mode.This is patently false and has been disproven in countless traction tests. Two motors on the same "axle" (I put that in quotes because there is no axle and no mechanical connection between both wheels) means both motors are mechanically independent of each other and the only way they can turn together is through software control. In principle, this seems like a pretty straightforward implementation. But in practice it is almost always inferior to a mechanical locking linkage.
The Hummer EV has this dual rear motor setup and it struggles immensely with dissimilar traction on the rear end. No matter what, the system can't figure out how to send power to the appropriate wheel while one is slipping. The same is shown to be true on the Rivian R1T and R1S. It struggles immensely with traction and correct power distribution.
Luckily for the Hummer EV it only has one motor in the front that is equipped with a mechanical locker, but the quad motor Rivians have no such saving grace and so they struggle immensely in uneven traction delta situations.
Watch the TFL video on the Hummer EV. It was pathetic lolRivian is not a good example because it's known for its weird/unexplainable off-road power control tuning. And AFAIK it doesn't have virtual lockers which it totally should so you can tell the truck how you want it to behave in more detail than just selecting a drive mode.
I haven't heard anyone complain about the Hummer EV virtual rear locker and there are plenty of vids of it doing what you'd expect it to do. But I also don't pay much attention to the Hummer. I'd like to know under what exact conditions it has issues.
I've seen the Moab one. Don't know if there is another one.Watch the TFL video on the Hummer EV. It was pathetic lol
