Truck Shudders at 3mph
WhiteBolt
Ed
CFL
Manufacturing
I almost never use 1PD, but often in normal or sport mode I get a slight shudder that last 2-3 ft before coming to a stop. I assumed it might be related to the regen trying to determine wheel speed and when to switch off.
Or maybe it could be the motor hold when inching up a slight grade. I feel a similar on-off hold when parking in my driveway which has a 2-3 degree incline. (happens going forward and reverse)
srspring551
Scott
WI
F150 Lightning Lariat 2023 ER, delivered 10-28-23
If its just in the steering wheel, that's the lane assist. If you get near the center line or shoulder line, you will get three quick shakes in the steering wheel. There should also be a red line show up on the bottom of your display showing you what line you crossed..
I had wondered about that possibility, but if it is the Lane Assist, it's getting confused with other markings on the road. I'll keep monitoring it.
Or we're just wandering a little to close to those margins, I was doing it a few times last night on a road trip, this thread came to mind and I wanted to reiterate the issue, you can adjust the intensity of warning IIRC.
