ZSC100
I can't believe when I search "25%" I haven't seen anyone posting about this issue. A week ago today my truck had service now SES light/wrench on. I drove it straight to the dealer, got a Mach-E loaner and have been getting daily calls from my awesome service advisor telling me they were working on it. He told me on the 3rd day they had done the BECM recall/update and that was fixed, but they were having issues with other things. DTCs for lighting and wiper motor recall among a few others. Then today, he called me and said while the service tech was test driving it a battery module DTC was set and they are now going to wait on advice from a BEV service specialist to proceed with diagnosis, but to expect a module replacement.
I can't believe I didn't get a pic of my actual dash before I took mine in, but a friend of mine now has the exact same issue just a week later, here is his pic:
The truck is totally drivable with only 25%. But this has me wondering if Ford switched the default "problem" power reduction from 3% which is common to 25% in a previous BECM update so that the vehicle would be drivable at least (this seems like a smart move).
I'd love to hear if anyone else has/is experiencing this right now? Both of these trucks are XLT SR EG311A and I have 49kmi on mine. where my friend only has 15k. My friend's has already had a module replaced too early on about 1mo after he got it last year.
I pulled my BECM DTCs before I dropped my truck off:
Code: P0B24 - Hybrid/EV Battery 'A' Voltage Unstable
Additional Fault Symptom (;21):
- Signal Amplitude Less Than Minimum
Status (-AF):
- DTC Present at Time of Request
- Malfunction Indicator Lamp is On for this DTC
Module: Battery Energy Control Module
Freeze Frame #1:
-MODULE_VOLTAGE: 12.0 V - Control Module Voltage
-VSS: 0.0 km/h - Vehicle Speed
-RPM: 0 1/min - Engine Revolutions Per Minute
-POWRPCK_STATE: Like KOEO - Power Pack NOT Available - Power Pack State
Code: P2C85 - Hybrid/EV Battery Voltage External Isolation Fault
Additional Fault Symptom (;1E):
- Circuit Resistance Out Of Range
Status (-6C):
- DTC Maturing - Intermittent at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
- Test not complete
Freeze Frame #1:
-EVENT_TIME: 43675861 s (Sat Dec 09 21:05:39 2023) - Event time
-TOTAL_DISTANCE: 76223 km - Total Distance
-MODULE_VOLTAGE: 14.8 V - Control Module Voltage
-POWRPCK_STATE: Like Remote Start - Non-moving Run state - Power Pack State
Status (-AF):
Freeze Frame #1:
Status (-6C):
- Test not complete
Freeze Frame #1:
