starrtech2000
Does the ProPower in the frunk stay on with the truck off?
No the Truck needs to be on for my 23 Lariot, perhaps a software update in the future @ford.com.Does the ProPower in the frunk stay on with the truck off?
Damn, that’s so frustrating. Way to make a great feature SIGNIFICANTLY less useful.No the Truck needs to be on for my 23 Lariot, perhaps a software update in the future @ford.com.
I didn't think of that, the outlets wont work unless the truck is started.The lightning (like every other EV on the market) disconnects the high voltage battery with a contactor. That contactor is only on when the vehicle is powered on. I believe its a safety design on all EVs.
The lightning's 120/240v power ports are powered from the high voltage battery.
So don't expect a software update for that. The 120/240v ports will ONLY work with the truck turned on.
Having said that. You can turn off the auto off timer, turn off the headlights, put the display in "quiet mode", lock the truck and leave it.
Along those lines, a software update can be made for a mode that simplifies those settings. That's essentially what Tesla's Pet mode and Rivian's Camp mode does. It leaves the truck on, and selects certain things and/or systems to shut off (ie, HVAC, interior lighting, screen) or in the simplest trigger remote start but allow a single door open. That would at least minimize the amount of things to turn off/on to utilize the Pro Power for an extended period of time.The lightning (like every other EV on the market) disconnects the high voltage battery with a contactor. That contactor is only on when the vehicle is powered on. I believe its a safety design on all EVs.
I have a similar one. Actually, I have 3 different portal coolers. Why? I have no idea..We use this https://www.amazon.com/dp/B08NCZF438 plugged into the 120v outlet in the truck bed. Really like it. It cools down from 100 dF to 5 dF in less than 25 minutes. It has an app so you can monitor the temp and voltage while traveling.
