How Do I Turn On Plug and Charge?
Edit: The solution was to cancel Blue Oval Charging Network and reactive it.
I turned off Plug and Charge by mistake a couple weeks ago while exploring the new FirdPass app layout. Since then I haven't been able to turn it back on. The slider moves from off to on, the screen dims with a loading wheel for a second then the slider moves back to off.
I verified Blue Oval Charge Network was active on Ford.com and there is a valid credit card on file. My phone is a Samsung Galaxy S21, and the FordPass app version is 5.0.2.
I haven't used DC charging since my home charger was installed but we are camping at the end of the month and I may need to. I'd like Plug and Charge to work if possible.
Ford F-150 Lightning How Do I Turn On Plug and Charge? 1000004403
Ford F-150 Lightning How Do I Turn On Plug and Charge? 1000004402
1) Reboot phone and try again.
If that doesn't work,
2) Delete app, reboot phone, reinstall app, and try again.
3) Delete cache, delete app, reboot phone, reinstall app, and try again. You may need to redo PaaK.
Tony Burgh
Tony
Western Pennsylvania
22 Lariat ER
I tried to shut plug and charge off and just get the rotating blue semicircle. I switched screens and plug and charge still on when I switched back Sorry, no help here.
Might be a transient bug in Ford Pass.
Nothing worked.
PreservedSwine
Fort Myers
2023 Lightning
Good luck.
FWIW, as I remember, If you have a membership with any of the popular DC charging outfits, it’s substantially cheaper to charge with that feature turned off.
potato
BC, Canada
2023 F150 Lightning XLT ER
Good luck.
I don't think you have to turn it off. You just have to activate the charger with the relevant app (Tesla or EA) before plugging in.
PreservedSwine
Fort Myers
2023 Lightning
That wasn’t my experience. However, it wouldn’t surprise me if it was inconsistent.
I had to turn it off. Having it enabled automatically defaulted to the forpass app authentication, and billed accordingly via the forpass app. losing out on my EA member rates.
This was in December, perhaps it’s different currently.
Try this:
Take phone and throw it to the ground...
Sorry, all out of suggestions.
Remember when the first step in troubleshooting was tapping on the gauge that was causing concern? And how sometimes tapping fixed it?🤣
Good luck.
I still have all or most of the 250 kWh that came with the truck. Hopefully, I can draw from that if I DC charge.
I'm not even sure I'll need to DC charge. Supposedly our campsite has a 50A outlet. Plug and Charge would be nice to have though.
To use the free hours you have to charge at EA, and use Plug and Charge or activate with FordPass or Public Charging / Charge Assist.
Danface
Dan
Central Mass
2023 Lightning XLT
If that doesn't work, throw the phone across the room!
ryun
Earth
Is there a way to do this on ford's website? That might work.
There's an EA station near my house. I stopped there this morning to see if I could get it to work. Two of the six stalls were broken and the others were occupied.🙄
If there is I can't find it. I also have no idea where to find my EA balance.
