Right Side Sensor Beeping When Nothing is There
ebkeys
Eric
Louisiana
F-150 Lightning
Teacher
Need to know if anyone else is having this problem. I have a 2023 F150 Lightning Lariat Edition with fold-in running boards. These board seem to have sensors in them to detect objects/people that you may run into. Whenever I back up, they automatically go off as if something is there. It startles me and I am in a panic with my head swiveling to see if there is something there. This has been going on for several weeks and is getting progressively worse. I took it to the dealer for them to examine, but while they could see and hear the issue, the could not fix it because the truck was emitting not an error code for the issue. I really like this vehicle, but this is becoming unbearable, especially when I am in reverse in the vehicle. I am hoping someone has seen this issue and can give me some pointers that I can give the dealership to fix this.
PreservedSwine
Fort Myers
2023 Lightning
I would take it back. The fact that there are no error codes isnā€™t really your concern. If they can replicate the error- it should be easily fixed by any tech worth his salt.
VTHokies
Jason
ā€˜23 F150 Lightning Lariat ER (Sept ā€˜23 build)
Good thing I kept my service receipt, hope it helpsā€¦. Said it was a faulty part (sensor module or something like that), they replaced it and havenā€™t had any issues since.
Ford F-150 Lightning Right Side Sensor Beeping When Nothing is There IMG_5243
glean
Jacob
Massachusetts
2023 F-150 Lightning Lariat
Thanks so much for posting. I have this issue, glad to know I won't be wasting my time. I will copy this so that the service can hustle getting it done.
My gripe, not an error just an overprotective safety system, is if I am in a parking lot and have to back out of a space, I press the accelerator and no movement but a message comes up on the screen to check my surroundings - nothing/no one behind me to run into/over. I have to push down really hard on the accelerator to override the warning.
Just have to live with that I suppose because I would like to be warned when backing up if there IS something there so I don't run over a little kid or hit an old lady...but not when there is nothing back there except air.
ciferguson37733
Dean
2023 F150 Lightning
Manager
I have this on/off. Will look for the sensors no to see if they are obstructed with mud or similar . Goes away after I run it thru a carwash. But agree with you - very irritating
Nlrkoa
Larry
Arkansas
2023 Lightning
I am having the exact same problem. Second service appointment scheduled for 7/2 for the same problem.
Electric Messiah
Davis
Massachusetts
The right side sensor on my 22 Lariat ER, is also challenged with beeping hallucinations.
Yes that was my fear too - that I'd end up rear ending the bank building behind me, the police would come, and I would die in a hail of bullets, or some such tragedy.
Wjburgin
Will
Columbus, GA
2023 F-150 Lightning Lariat / 2018 F-150 Lariat
Real Estate Development / Timberland Management
I have the same issue with the same truck. I just turned off those sensors, although an update turned them back "on" and I about jumped out of my skin. I'm glad to know it was able to get fixed. I just haven't had time to take the truck in to be looked at.
ebkeys
Eric
Louisiana
F-150 Lightning
Teacher
Thank you very much. I will take this to my dealership on Monday.
ebkeys
Eric
Louisiana
F-150 Lightning
Teacher
I plan on it. My dealership is usually responsive.
