Air Conditioner Compressor Issues
JMR
Arkansas
Lariat+ Lightning Ordered
My fan is screaming in the driveway when the ac is on and truck not moving, very loud actually
I think (hope) what you're hearing is normal. The cooling fans are loud and it sounds like an ICE truck running when they're on.
Reactions: JMR
lightspeed
2023 Lightning Lariat ER
FYI your compressor noise sounds totally normal for the electric compressors in Lightnings/Mach-Es/etc.
The fact that it ramps up and then shuts down is obviously bad, but the noise is normal. Obviously, the AC system is encountering an error and shutting down the compressor.
I'm surprised a dummy light didn't go on. Did you ever get an OBD error code?
JMR
Arkansas
No, the truck is not throwing error codes. I disagree that the noise is normal. This is the third summer I've owned the truck and the noise didn't start until the end of last summer. I took it in to have it looked at when the noise first started but the dealership claimed they couldn't replicate it (it wasn't consistent at first) and, because is was working, there was nothing more they could do.
lightspeed
From your video, it sounds like every other Lightning/Mach-es I've heard.
But some people have said it gets louder if the refrigerant is low. Did they try adding any? If refrigerant is low, some AC systems will automatically stop the compressor to save it from damage.
JMR
Arkansas
It does work continuously as long as the truck is moving which makes me think it's probably not a low refrigerant issue, but maybe it is.
Nothing's been done yet. I goes in on Monday. I'll update once I find out what the problem is.
My AC compressor is definitely loud and ramps, but I don't think it has ever sounded like that. I hope the dealer is able to pinpoint the issue.
Ford Motor Company
Official Ford Account
Ford
F-150
Hi there, Brandon. This A/C concern doesn’t sound like something we want you to experience with your Lightning truck. Should you need further assistance, please send us a PM with your VIN and the name and location of your Ford dealer? I'd be happy to look into how I can assist you on my end. To send a private message, just click on our username and select "Start Conversation".
BennyTheBeaver
I've owned 2 Lightnings. The first one didn't sound like what you posted. The second one does. I'm taking mine in to have it looked at as well.
You miss understood. I don't think anyone will ever say their A/C is not loud, just something we're going to have to live with. It's the particular sound that it's making that is a concern in this thread. Mine sounds like an ICE engine idling. Nothing unusual about it (ignoring the volume of the sound).
JMR
Arkansas
Ended up being a shorted out relay. They replaced the relay (which was part of the entire fan assembly, so all new fans) and the A/C is working again. I don't think they even looked into the compressor noise. There's no mention of it as part of my issue or anywhere in the technician notes. It's still noisy but working.
Jesse-Infotainment
2024 F150 Lightning Flash
My AC stopped today.. Air blows but not cold.. No Codes at all.. so now I will have my first deale rvisit in years for a FOrd. Hopefully it is something easy.
NO heat either.. Guess that makes sense since its a heat pump
