BlueCruise hyper speed
hardy
Hardy
naperville,il
f-150 lariet lightning
I'll review, thank you. I really hope that's what it is. It didn't use to happen until recently
This has happened to my truck numerous times, to the point where I refuse to use it at all. Very scary when it suddenly jumps 15 or 20 mph faster. Yhis has happened from day one.
Electric_hillbilly
Enrique
Grass Valley, CA
2023 Lighting
Military
It is kinda scary, I hope it can get fixed, it is a nice function when it works
MichaelPNW
Michael
Marysville, WA
Ford f150 Lightning Lariat ER
I've seen weird behavior when driving in Canada with a USA lightning. It seems to have issues with the Kmh to Mph conversion, and sometimes will leap up to 80 mph in a 120kmh zone.
marc_hanna
Marc
Nova Scotia
Get what fixed? It's a feature you have set, which you can turn off and it will no longer happen.
He wants the feature to work properly. I don’t think that’s an unreasonable expectation. I’m not in agreement with this mentality of just accepting that some things don’t work on your vehicle that is under warranty.
Use the feedback reporting system to tell the engineers of your problem, try to time the report just after the next repeated incident.
Runaway Tractor
Yes
Not unreasonable but I'm not sure what is actually a problem that needs to be fixed? It sounds like it is doing exactly what he told it to do with a speed offset?
The speed limit database having incorrect information is a global problem, not just ford. That information sucks for everyone which is why I disabled it on my Tesla too. I don't think that is Ford's data to fix either. That is just garbage in, garbage out.
What I found interesting in driving trips with my Mach-E and my Lightning is how this feature performs DIFFERENTLY.
In the Mach-E, I get the rare "I'm reading the sign in the truck weigh area" problem. In the Lightning, I got so many "I'm using the database, and it's way wrong" I had to turn the feature off. I have no idea if it was location-based or not, but it was horrendous. I gave some very direct feedback via the app in the truck.
WilliamRobert
Western Pennsylvania
2022 F-150 Lightning, 2021 Mustang Mach E
happily retired!
Hey there. I'd like to look into your Blue Cruise issues on my end. Could you please send over a message with your VIN and estimated mileage to get things started?
I hope you fix this, this is happening to my 2023 Mach-E also.
Electric_hillbilly
Enrique
Grass Valley, CA
2023 Lighting
Military
Exactly. Vehicle should work at 100% I expect nothing less, specially for a truck that has less than a year and barely 18k miles on it.
Expectations would be different if it was a beater from the 80s/90s, but it is not, and I expect it to perform.
Electric_hillbilly
Enrique
Grass Valley, CA
2023 Lighting
Military
I don't use the speed recognition because it would slow me down from 70 to 35 or 55 and I thought I was going to get rear ended. Everything was working fine until recently. Of course, speed rec off
