Remove sun visor stickers?
dustintinsley
Dustin
Salem, CT
Anyone have a reliable way to remove the huge stickers on the sun visors without damaging the visors?
COrocket
F-150
Gently with a hair dryer or heat gun and you’ll eventually be able to pick at and lift the corner with your fingernail. Just be careful to slowly warm it so it only gets just hot enough to make the adhesive pliable again. There will still be a very slight outline where the sticker was but in my case it wasn’t sticky so I left it alone instead of trying to clean the fabric further
dustintinsley
Dustin
Salem, CT
do you have any pictures of the outcome?
Lightning Rod
North Coast
2023 Ford Lightning Lariat ER
CNC PROGRAMMER/MACHINIST
I've been debating doing this all summer. Thanks for the inspiration.
Lightning Rod
North Coast
Done!
It took all of 15 minutes to remove all 3 stickers. There is a slight glue imprint left but I'm confident that I will figure a solution to that in the near future. It's so much better than those loud, ugly stickers that takes away some of the beauty and elegance of the cab's interior.
Thanks, OP. :cool:
BennyTheBeaver
Done!
Thanks, OP. :cool:
If you figure out the glue imprint please post your solution.
Lightning Rod
North Coast
Yes, this is my concern. I need to figure out a way to get rid of the glue also.
I did a quick Google and saw this...
https://www.ferrarichat.com/forum/t...glue-left-behind-on-the-visor-sticker.359853/
I will try some of this this weekend. I will perform spot tests on the other side of visor first. I'm not sure if this Ferrari visor is cloth, leather or what.
Also found this....
dustintinsley
Dustin
Salem, CT
