dustintinsley
Anyone have a reliable way to remove the huge stickers on the sun visors without damaging the visors?
do you have any pictures of the outcome?Gently with a hair dryer or heat gun and you’ll eventually be able to pick at and lift the corner with your fingernail. Just be careful to slowly warm it so it only gets just hot enough to make the adhesive pliable again. There will still be a very slight outline where the sticker was but in my case it wasn’t sticky so I left it alone instead of trying to clean the fabric further
If you figure out the glue imprint please post your solution.Done!
It took all of 15 minutes to remove all 3 stickers. There is a slight glue imprint left but I'm confident that I will figure a solution to that in the near future. It's so much better than those loud, ugly stickers that takes away some of the beauty and elegance of the cab's interior.
Thanks, OP.
Yes, this is my concern. I need to figure out a way to get rid of the glue also.If you figure out the glue imprint please post your solution.
I did a quick Google and saw this...Yes, this is my concern. I need to figure out a way to get rid of the glue also.
Ferrari is leather. The 2nd video may be vinyl sun visors? But isopropyl alcohol should work as long as it doesn't discolor the clothe.I did a quick Google and saw this...
https://www.ferrarichat.com/forum/t...glue-left-behind-on-the-visor-sticker.359853/
I will try some of this this weekend. I will perform spot tests on the other side of visor first. I'm not sure if this Ferrari visor is cloth, leather or what.
Also found this....
