Rick, I have had my system for about 18 months. The first 9 months were difficult and frustrating to say the least. But, to be fair, everything now appears to be working as designed without issue. I test the system, under load, monthly by turning off the main breaker.Does anyone even have a "working as intended" system set up? I feel like I've only ever seen a couple people say they were close.
Thanks for sharing. It's nice to know the system can work. It's a pricey install, so I really needed to see others succeed before I would even consider it. I also have solar, but not from sunrun, so I expect complications. I'm curious if the FCSP can backfill other battery storage systems. My Solar company has their own home battery backup system that I'd consider before the HIS installed by Sunrun.I also have a working system. Like Mike, it was frustrating at first. It was working initially, and then stopped, and then a complete reset, and now seems to be working reliably now. I don't test it every month (also by turning off the main breaker), but do so occasionally, mainly to prove to my super-skeptical wife that it actually works.
If you don’t mind me asking where exactly did you find this notice of “A new way to manage Intelligent Backup Power is ready for you”? And have you in fact been able to access this new feature? Any additional information you can provide would be greatly appreciated.
BF150A, I received an email yesterday that included the notice shown in my original email. Here is the hyperlink that was included: https://energy.ford.com/welcomeIf you don’t mind me asking where exactly did you find this notice of “A new way to manage Intelligent Backup Power is ready for you”? And have you in fact been able to access this new feature? Any additional information you can provide would be greatly appreciated.
I’ll check my junk mail file and see if that’s where my notice ended up. No, no email notification found, however, I followed the link you provided and was able to login on the Ford Welcome to Ford Energy Management webpage. Thanks for making this bit of information available.BF150A, I received an email yesterday that included the notice shown in my original email. Here is the hyperlink that was included: https://energy.ford.com/welcome
When I log on, it shows departure time, charge settings, back-up power range reserve. It also includes a "stop transfer" button which stops the vehicle to home power transfer. The edit portion of the "charge setting" and "departure time" are not yet active.
using that link and your Ford.com credentials will bring up a control panel showing SOC and departure time settings, view only data.I assume this does noting for me as I'm using the bed outlet connected to an automatic transfer switch.
If you have the Home Integration System installed, this is what you see when you log into https://energy.ford.com/ :using that link and your Ford.com credentials will bring up a control panel showing SOC and departure time settings, view only data.
