First Mod: Rear Seat Release by Builtright Industries
Sneakypetie78
Pete
Marina del Rey, CA
2013 F150 limited
General Contractor
Seat bottom gets lifted almost all the way up, then push, or bump the seat back into the latch.
vorguy
vorguy
Harry
Sacramento, CA
'24 Lightning Lariat, '03 F-250 6.0
Airport maintenance
Check how it latches with the seatback down. Mine wouldn't latch either and I noticed the plastic tab would get stuck between the bump by the pin (see first pic) and the black bracket (fourth pic). It prevented it from latching completely. I had to bend the bracket a bit.
With underneath storage, I don't need any more space.
MaintGrl
Marsha
El Sobrante, Ca
So, I purchased the mod and installed, seemed to go together easily. But w/the lower seat up, when I release the latch, the upper seat will not release, it feels like it wants to, or is released, but will not come down until I undo the lower seat and begin to lower it, then the upper will drop. Not a big issue, as long as I remember that procedure...A longer "Factory" pull strap would have been helpful.
dustintinsley
Dustin
Salem, CT
Agree. I installed this but to be honest, the storage back there is negligible. I do have a Lariat so have an amp and stuff back there from factory. If I had it to do ver again I would ave saved the $.
Jake24
Jake
Sicamous BC
'24 XLT Avalanche 9.6kW
$10.42 Amazon - can't go wrong - 2 minute install ~ w/alloy tab ~ works perfect!
$50 Builtright w/plastic tab ~ f'n joke.
Ford F-150 Lightning First Mod: Rear Seat Release by Builtright Industries 51pwK0Ic2qL._AC_SL1030_
Ford F-150 Lightning First Mod: Rear Seat Release by Builtright Industries 20240731_133352
Scorpio3d
SS/IBA car wash owner
$10.42 Amazon - can't go wrong - 2 minute install, alloy tab, works perfect!
$50 Builtright plastic tab :poop:'s a f'n joke.
Can you post a link?
Scorpio3d
Well, that’s not fair. 😭It is not available in the US. Only in Canada.
