scruvs
I edited this post to show how to replace a broken retractable hook (grocery bag hook) in the frunk.
1. Order Part.
The hook is part no. NL3Z-26313A68-AA and can be ordered here.
My Ford Dealership sold the hook for ~$22. I ordered from the site above for $21, so I didn't have to take a trip back to the dealership.
2. Remove Old Hook.
To remove the old hook, it helps to see the prongs on the back of the hook. I waited for the new part to arrive to inspect the prongs, but the prongs on the old hook didn't match the new hook. Below is a picture of the old hook. The tape on the back of the housing is explained later.
The old hook has prongs on the top and the bottom.
To remove the old hook, I used needle-nose pliers to clasp on to the bottom of the housing just above the bottom bezel. There is an existing slit above the bottom bezel that allows you to clasp onto the bottom of the housing. Then, pull up and out as shown in the video below.
3. Clean Up Tape.
On my 2023 XLT, the passenger side hook closest to the cab had weatherproof foam tape on the back of the hook housing on the backside of the frunk. The passenger side hook closest to the front bumper on the side of the truck did not have weatherproof foam tape on the back. I'm assuming the two hooks closest to the cab are taped, but not the ones on the sides, but I haven't checked the driver side to confirm.
The image below shows how the weatherproof tape tore as I removed the hook.
I popped off the side panel to access the back of the frunk and peeled off as much tape as I could with my fingers. A couple blisters later, most of the tape was removed.
4. Insert New Hook.
The new hook doesn't have prongs on the bottom (sorry no photo). This makes it much easier to insert, and likely easier to remove later. Insert the top first and then push in the bottom.
5. Tape the Back.
I taped the back of the hook with some rubber tape. I only taped the seams and decided to use removable tape instead of permanent Flex Seal, so that I could remove it later if I needed to replace this part. Below is an image of the bottom of the hook showing the tape on the back side. And, a picture from the back showing the new tape on the seams. Next time that I open the side panel, I'll add another piece of tape to cover the daylight showing at the top of the hook on the back side.
6. Enjoy.
I hope this helps anyone who has a broken hook and wants to replace it.
-scruvs
Edit: Deleted this post after I answered my own question.
Added a How-To in the original post in case anyone else needs to replace a broken hook.
1. Order Part.
2. Remove Old Hook.
3. Clean Up Tape.
4. Insert New Hook.
5. Tape the Back.
6. Enjoy.
-scruvs
