Car scanner app works pretty good with CarPlay
Eldricks
Rick
CA
F150 lightning lariat
Maintenance
I’ve been using car scanner with CarPlay, would be nice if we could make our own custom screens with values we’d lIke to track.
Ford F-150 Lightning Car scanner app works pretty good with CarPlay IMG_5160
Ford F-150 Lightning Car scanner app works pretty good with CarPlay IMG_5161
Ford F-150 Lightning Car scanner app works pretty good with CarPlay IMG_5164
carys98
Cary
Raleigh, NC
2023 Lightning Lariat SR
You can. Create new pages on your phone and they will show up in the menu. It only supports text, no graphs or gauges. Here’s the one I created a while back to monitor the 12V.
Ford F-150 Lightning Car scanner app works pretty good with CarPlay IMG_0977
driel
kentucky
2013 Platinum Lightning
univerzity Professor
Can you give more info on this app? What scanner do you need to connect to?
Ventorum94
FL
Chev Avalanche, BMW 550i, Tesla MY, Tesla M3
Mechanical Engineer
Which adapter are you running with this ?
Hard to find a good one that works with IOS…
OBDLink CX works great for me. Whatever you buy, be sure it’s BLE (Bluetooth Low Energy), not older Bluetooth, for less power drain.
carys98
Cary
Raleigh, NC
I’ve been using this one. I keep it plugged in all the time and I haven’t had any battery drain issues since I got the BMS replaced. It also works with ABRP and displays SOC on the map.
https://a.co/d/7Yklimt
App is called car scanner and the device is Veepeak OBDCheck BLE ($31.99 on Amazon).
https://a.co/d/8Oe8ZEZ
For whatever reason I got the + version for $10 more over a year ago. Still don't know what that gives me but I can also recommend it: https://a.co/d/9UHlFG4
I would not trust it to stay plugged in all the time. The OBDLink CX seems like a better choice for that, albeit at twice the price.
FreshDaddyE
Raleigh
2023 F150 Lightning
Eldricks
Eldricks
Rick
CA
Maintenance
That's so helpful. And you just leave it plugged in all of the time?
Yes, I leave it plugged in. Once CarPlay connects to sync I open app on sync screen and tap on connect, when I get to my location I tap on disconnect. If I forget to do this car scanner wont connect the next time and I have to remove OBD device and re insert and this resets it.
mmcguirk
MD USA
F-150
Anybody figured out how do do this with Android Auto?
sd25
NJ
Acura MDX, F-150 Lightning Lariat ER, Rivian R1T
mr.Magoo
2022 Lariat ER, AMB
CX is nice because it also works with ABRP
MX is nice because it also works with Forscan (and it's faster)
The difference in powe use between ble and "old bluetooth" is negligible.
Once the truck is off and no communication is made both (obdlink anyway) versions will enter a power "saving" mode.
