Anyone bought and installed the Eibach Pro Kit?
Iroc34a
Roc
23 Lightning Platinum
Mechanic for American Airlines. GSE (ground equipment) 37 years. Worked on everything from Lawn mowers to Boeing 747's.
It is unfortunately, I think I found it slightly cheaper. Side note I'm not entirely sure you need it. The wheels might stay within spec with the 1.5 inch drop. Might be worth installing the McGaughy's kit and checking before doing the icon camber kit. I didn't check and just had the shop do both.
Great that was what I was thinking. I'll try it first. Thanks a lot !
KHines
Kevin
Delaware
I dropped my rear 1.5” using the rough country kit. I checked the alignment values after and the toe was able to be brought back into spec, the camber then measured -1.8 degrees and max neg spec from Ford was -1.5 degrees. I opted to not install the camber kit as I saw that trouble not worth the correction (and, my 5’9” 160lb self was holy s**t worn out after battling with the massive bolts and springs - big ups to the dudes that do this work every day). As long as the toe is correct the additional wear from neg camber should be minimal.
Now, if you regularly tow/haul, the values might get a little crazy back there.
edsasso
Ed
jupiter FL
2022 bronco, 2022 expedition, 2023 lightning
HVAC
I did the Eibach springs, shocks and Icon camber kit. I love it and the truck performs very well. For example, I hauled 2400 lbs in the bed only 4 times this past weekend, no issue and didnt sit too lazy when loaded. The best part is the truck will still go 0 to 60 really fast (no downshifting and so on) and you cant tell there is a load. Here is a pic of me pulling off a little roof while loaded.
Iroc34a
Roc
Good luck! Let me know how it turns out.
So I installed the McGaughy's kit this morning. Lowered the rear 1.5". Looks way better. I'll post some pics tomorrow after I get the alignment checked. Just eye balling it. Doesn't look like I'll need the camber kit .
Iroc34a
Roc
So, with the McGaughy lowering rear spring mount. It dropped the rear 1.5 inches. Better, but I think just a little more would be nice! Went to get an alignment today. Some shops are still not able to do the Lightning! NTB you listening? Just eyeballing Camber should be ok. Toe appears in a little more. Have another appointment Tomorrow. Top pic is after.
Ford F-150 Lightning Anyone bought and installed the Eibach Pro Kit? Lightning rear lowered
Ford F-150 Lightning Anyone bought and installed the Eibach Pro Kit? new wheels
KHines
Kevin
Delaware
Whenever the toe is adjusted, especially on the front, it’s necessary to then calibrate the radar and the cameras or else things could get interesting. Performing these calibrations requires expensive equipment and specialized training of a competent tech that actually cares about doing the job correctly. As a pro tech myself, your best bet is going to a dealer. And look for a dealership that looks put together and presents themselves well.
My 2 cents
Iroc34a
Roc
My 2 cents
Thanks for the heads up. I will double check the shop is capable of this.
Iroc34a
Roc
Sitting in the Ford Dealer right now. Service writer just informed me that all the specs are right within limits. Good to go. No camber kit needed for the McGaughy lowering spring perch. Good deal!
