Warm Air on Cold Feet?
Tinnemaha
Grant
Northern California
'24 E.R. Lariat & '06 Toyota Tundra
Forum,
'Tis a very minor issue, but I used to enjoy (in my ICE truck) blowing the heater air on my bare & cold feet. I've not figured out how to do that in my lightning though; Not sure if that's just the way it is or if I'm missing something. If you happen to know, please educate me.
FWIW, I LOVE my truck ('24 ER Lariat); the heated seats & steering wheel more than make up for the loss of floor heat, it's just that my truck is smarter than me (not saying much)
Go into your HVAC settings, select to foot vents, close the recirculation and bump up the temperature & fan speed, these settings should get your tootsies toasty in no time.
WOW, I haven't driven barefootin' since I was many moons younger and was headed where the weather suited my clothes, looking for adventure with whatever comes my way...takes me back, thanks!
Tinnemaha
Grant
Northern California
Thanks a ton, Taxman; Worked great for me this morning!
Tony Burgh
Tony
Western Pennsylvania
22 Lariat ER
Now we’re born to be mild?
Reactions: chl
Of note, most automatic systems run a higher air temp when using lower fan speeds. Try switching to floor and running a lower fan speed.
strmwzrd
Nebo, NC
F-150 Lightning Lariat
No heat pump here (2023). My feet and legs are constantly cold. I do the trick (turn off auto, move vent to lower and crank the temps high and higher). I actually have better luck hitting the "max" non-button. Even so, it's not optimal.
