Home charging using 220v
InTheCloud
CA
Mach-E GT, Lightning XLT ER
Rough guess is that the outlet is 220V/30A, which gets a Tesla Model 3 LR in that ballpark.
30A x 220V = 6600 W (6.6 kW)
Model 3 LR battery capacity: 82 kWh
6.6 kW/82 kWh = 0.0805/h = 8.05% battery capacity added per hour
Model 3 LR range = 341 miles (note: driving efficiency of ~4.1 mi/kWh)
341 mi. x 8.05%/h = 27.45 mi/h range added
(some line losses may be incurred, dropping the actual range added to the stated 24-25 miles per hour)
The 2024 XLT with the SR Battery is 98 kWh, and has a range of 240 miles:
Lightning SR battery capacity: 98 kWh
6.6 kW/98 kWh = 0.0673/h = 6.73% battery capacity added per hour
Lightning SR range = 240 miles (note: driving efficiency of ~2.4 mi/kWh)
240 mi. x 6.73%/h = 16.16 mi/h range added
(some line losses may be incurred, dropping the actual range added)
(note: doing the math at 25A outlet gets 13.5 mi/h range added for the Lightning, and 22.8 mi/h range added for Tesla Model 3).
What can you do? Well, drive the truck slower, accepting the inefficiency because truck. Everything after that is going to cost money.
Upping your amperage will mean a new breaker (assuming the main panel has room/overhead for the raised amperage), new wiring (pulling out the existing gauge wire and going for a wire gauge rated for the new amperage), a new plug (the plug may be rated for 30A), and potentially a new EVSE (charger), as if you are using a mobile adapter it is only rated for 48A. It's not terribly expensive, but with an electrician you could be looking at a ballpark of $1k (the good news is you can claim 30% of that cost back on your 2024 taxes on the Inflation Reduction Act).
Monkey
Somewhere in the mountains
OP didnā€™t give us too many specifics, but assuming heā€™s using a gen-2 Tesla UMC with a NEMA 14-50 plug on it, he would be getting 30A at 240V (7.2kW). It is possible heā€™s using a gen-1 Tesla UMC, which can deliver 40A at 240V (9.6kW). Likewise, Tesla sells the ā€œCorded Mobile Connectorā€ which is the same as their UMC but with a permanently wired 14-50 plug and it also delivers 40A.
So to answer OPā€™s question of what he can do to improve charge times for his Lightning, he can probably get a faster charge cord or EVSE to deliver 40A on his current circuit. It doesnā€™t seem like much, but going from 30A to 40A will increase his charge rate by 30%. While miles per hour charging is a terrible metric to go by, a 30% increase would mean that if heā€™s currently getting 15MPH of charging on his Lightning, it would increase that to 19.5MPH of charging.
If OP already has a unit delivering 40A, then thereā€™s not anything he can do other than to upgrade the charging circuit and wire or add a new circuit on a 60A breaker, which will allow him to hard-wire an EVSE for charging up to 48A (11.5kW). Charging at 48A is a 20% increase over charging at 40A. Or s 60% increase over charging at 30A.
He could upgrade or install a new circuit greater than 60A and a EVSE to utilize it, but it would provide no benefit to either of his current vehicles.
A 2024 Lightning comes standard with a single 48A onboard charger. There is no way to upgrade this due to the level of integration and differences in the electrical system compared to a dual-charger setup. The 2022 and 2023 model years came with dual charger setups for up to 80A charging (19.2kW) and 2024 Lightning only gets the dual charger setup as an optional upgrade available only to commercial fleet customers.
Jseis
SW Wa
I think 80 amps sustained needs a 3 AWG line. That is likely over $1 / foot cost for THHN copper installation. 6 AWG might be sufficient for the Ground.
My electrician indicated that our cooler coastal environment, wire through ceiling joists (not conduit), length of run, charger duty cycle, cable type, etc. factor in. Iā€™m with you on over sizing though ā€˜cause I too thought 3 AWG copper was likely.
Iā€™ve been studying our garage layout for the re-location so I can better serve the LTE and MME. The current location serves the truck, other vehicle has to back in. A better location that forgoes outside charging (future visitors!), reduces the charger service wire from 35ā€™ to 12ā€™.
So future proofing important. That also means swapping out the 100 amp panel for a 200 amp.
You are right, I went back and checked, it was 3 AWG copper. The way it is now I charge nightly 4.5-5+ hours, put 32-42 kWh back in, works great. 80 amps seems a bit much for my needs. In the winter I charge to 85% ā€˜cause storms knock power out and having nearly 80 or so kWh on backup is a good thing.
I've read many of your posts using this abbreviation ......
what are the words that represent the letters in your nomenclature ??
Jseis
SW Wa
šŸ˜‚ LighTning Extended (Range) or could be: LariaT Extended (Range)ā€¦ either way.
Sometimes Iā€™ll type ER LT but LTE is the same thing. Iā€™d guess Lariat makes most sense.
Was easy to type.
PS, I enjoy your posts & admin.
EG Evgoer
egevgoer.com
F-150 Fighting
Manager
It seems your Lightningā€™s lower rate may be due to its onboard chargerā€™s limitations or the adapter setup; checking Fordā€™s recommendations for home charging setups might help.
Was easy to type.
Thanks for sharing, I had visions of:
Light Truck Electric ala Mustang Mach Electric
htobin
Howard
Ovalo TX
Iā€™m a very non-technical guy but my Ford suppled charger on 220 v will charge up to 85% over night from as low as 10% or lower
flyct
Jerry
South Florida
'24 F-450 Platinum & '23 Ford Lightning Lariat & 2 Tesla Model Ys
Blissfully Retired
I have Tesla Model Y and Lightning. They both charge at the same kW charge rate but the Lightning is almost 40% less efficient, so it takes 40% longer to replenish for the same miles driven.
Example, my trip from our house to our Cabin is 125 miles. The Tesla uses 34 kWs and the Lightning uses 59 kWs to drive between houses, With our 60 amp Tesla Wall connector, which feed 48 amps, it takes about 3 hours to recharge the Tesla and about 5 hours to recharge the Lightning for the same trip. It's basic math!!!
When using a Tesla Mobile Charger plugged into a 50 amp outlet it takes 5 hours to recharge the Tesla and 8.8 hours to recharge the Lightning for the same trip.
To me, a lot of the confusion comes from people posting in multiple different units. For those that don't understand the relationship, it gets real confusing.
Miles is a near useless measure for charging as it changes by usage and weather. And, as you note, some vehicles are much more efficient than others.
In your example above, you mention how the Wall Connector is 48amps. 48 x 240 x 93% (for loss) = 10.7kW at best. So, for your trip example:
34 / 10.7 = 3.2 hours
59 / 10.7 = 5.5 hours
Yes, basic math.
If you look at the trip, 125/34 = 3.7 miles per kWh. 125/59 = 2.1 miles per kWh. Big difference. Similar between the Lightning and Mach-E.
Flipper
Steve
2023 XLT, ER, Lightning, 312A, Azure Gray
Sales Engineer
I use my tesla wall charger @ 30amps with the lectron adapter and I get around 14 miles per hour which works fine for my use
ciferguson37733
Dean
2023 F150 Lightning
Manager
Teslas get about 2x the miles per KW than the F150. So your charging rate is the same between the Tesla and the Lightening. Your Tesla is gaining range at 2x the rate of the Lightning
Vcrpromo
Victor
San antonio tx
2023 ford lightening
Just wondering about other people's experience with charging I'm using a home charger actually using our Tesla cable plugged into our extra 220v outlet with an lectron adapter. My wife's model 3 charges at 24-25 miles per hour. My new lightning I'm only getting about 13 miles per hour can anybody tell me if I'm doing something wrong or how to increase the miles per charge time
My 2023 lightening gives me about 15 miles sometimes only 12 with the original Ford charging system.
