$200 48amp Amazon charger
Hank42
NY
2022 Lariat ER
FWIW, I'm OK with OP using this thing - just check up on the plug FREQUENTLY.
I've had a LEGIT brand (GE) charger melt the outlet. Someone noted "cheap Home Depot" outlet - yeah, best to get something better than consumer grade 14-50R, but even then, check those contacts - unplug ang plug it in now and again to make sure the contacts are clean and there's no sign of melting. My me, the code has changed from "hardwire" to "must have a disconnect" (by means of a 14-50) - I get the disconnect reason, but it creates this melting problem!
TMND
usa
Lightning
ag
It may only be day two but so far I love this thing!!!
Steady 9.1 at 38 amps
I couldn’t rely on the connector that came with the vehicle to give me more than 3.1 kw on 220 (would occasionally bump up to five or six for a few minutes). And no one at the dealer was helping me with that just taking my truck for days on end and not addressing the issue.
ytwytw
Toronto, Canada
2023 F150 Lighting ER Lariat
double check the temp of the wiring and connections of the charger
I had a $200 mobile 48amp charger before, and the charger went up to 65-70C degree after 1.5h of 48amp charging.
Definitely out of my comfort zone, returned and got j+boost portable charger instead and its much cooler and even smaller
TMND
usa
Lightning
ag
Holding at 43C I have been checking it periodically. put a fan on it and it’s down to 41 now.
I will update more to this overtime, but I am in agreement with the few here that take no issue with the affordable nature of this. I spoke with a electrician with 35 years experience he assured me everything is properly wired in our shop for the equipment and that it doesn’t matter if it’s a $3000 component or a three dollar component either could start a fire if things aren’t right. He said just use your common sense and monitor it.
RickKeen
Rick
F150L SR Pro
sw engineering manager,
Loving the Emporia I bought. Have it hardwired and running at 48 amps. In regards to having a disconnect, the breaker sub-panel is right next to it, so that is satisfied. But yeah, its $399.
Even if you convert to having it hardwired, you will still want to monitor to make sure all the connections are tight and nothing is getting hot. The breaker itself is another weak point where the wires can work loose under the set screw and generate heat. Especially if the screws were never torqued to their specified torque (as actually measured with a torque wrench).
The other thing to consider here is liability.
Using a non-rated charger that even advertises it pulls more power than is legally allowed, will likely invalidate whatever insurance is covering where this is located.
IF something were to happen insurance can come back and say that nothing is covered.
I hated dropping $2400 to get my charger installed when I could have done it for less than half that, but keeping my homeowners insurance valid was worth it.
TMND
usa
Lightning
ag
Life is full of risks some avoidable, some not, most are all about the choices we make. The number one thing that will keep you safe in any situation is being aware of the risks involved. I also have a wood-burning stove to keep warm which if my house burned down my insurance company would probably try to blame that too. Though they are aware of it and chose not to drop me for having a metal box full of fire in my living room. Safety aside I love the heat from it, and I hate the sound of my furnace kicking in. and yes, the number one choice for choosing a woodstove was the same for choosing this charger affordability 🤷‍♂️
Life is full of risks some avoidable, some not, most are all about the choices we make. I also have a wood-burning stove to keep warm which if my house burned down my insurance company would probably try to blame that too though they are aware of it and chose not to drop me for having a metal box full of fire in my living room, but I love the heat from it, and I hate the sound of my furnace kicking in. and yes, the number one choice for choosing a woodstove was the same for choosing this charger affordability 🤷‍♂️
Its a nice saying, except this risk isn't unavoidable. In fact, avoiding it is actually pretty easy
TMND
usa
Lightning
ag
I could never go outside and stay locked in my living room my entire life, and be safe too, but not the choice I make. I mean if safety is the number one concern here flying is a lot safer than driving. Maybe I should trade this in for a plane. Haha. Oh wait I couldn’t afford that either.
look, I created this post to share my experience with a bargain level two charger for the people that just simply can’t afford the other options not debate the risk versus reward. Just because the first time in my life, I’m able to afford a new (used 6000 miles or I would’ve gotten this for free 🙄) vehicle and have wanted one of these since they first came out. But couldn’t afford the fancy stuff. I just shouldn’t have gotten a Ford lightning?
I appreciate the constructive criticisms and the concerns and they’ve all been noted. My electrician has actually seen this and has no concerns as long as I keep it at 40. I will monitor daily as I’ve said before this is at work so I am watching this within 50 feet pretty much all the time that it’s on it and will check the temps and connections periodically.
next post will be a meaningful update in a few weeks
You completely misunderstand.
I'm not saying you should avoid life or avoid every possible risk
I'm saying that if you spent $200 more on the UL Emporia you wouldn't have to worry about your insurance...
Sheesh dude.
shelnian
Ian
Seattle
Firmware and software is more than likely Chinese so when you connect with the app, you are giving them access into your wifi system, phone, computers, etc. I would stick with products you can trust.
TMND
usa
Lightning
ag
Out of all the concerns with the product itself that right there is my number one.
