butterfb
Brett
Orlando, FL
2023 Lightning
Senior Support Engineer
Greenwire is intact, again the start up sequence goes and light goes on only when connecting the wire to the hot post, but when plugging it into any fuse port it will not light up at all.
how are you connecting to fuse box? Are you using the provided piggyback and plugging in both fuses. The one that came with the emblem and the one you removed from the fuse box location?
[/QUOTE]
Using piggy back with the 10 amp pulled from the fuse port that I plugged it into. Was not sent any other fuse, are two required?
bigtomlandry
James
San Antonio, TX
2023 F150 Lightning XLT SR
[/QUOTE]
yes. Your logo should have come with 2 5 amp fuses with the piggyback harnesses. Both ports in the piggyback harness need to be filled for it to work. One of the 5 amps with the logo and one from the one you pulled from the fuse box
BennyTheBeaver
Make sure the fuse for the emblem is in the right spot if there are 2 different fuses on the FuseTap (it's the fuse across from the wire coming out). The top spot with the wire coming out is for the item you're tapping and the lower spot is for the original fuse.
ma0am
Ryan
The Lake
F-150 Lightning Platinum
Just completed my install!
Fuse 137 as someone suggested, 20A fuse on bottom, 5A fuse on top of the fuse harness. Yes, you need indeed both I guess.
And below the green hidden wire that has to be connected for the animation to be enabled.
Ford F-150 Lightning F-150 Lightning LED Ford Emblem Swap. Step by Step Installation DIY Video. IMG_1408
Ford F-150 Lightning F-150 Lightning LED Ford Emblem Swap. Step by Step Installation DIY Video. IMG_1409
Fyatrk
Christopher
Tecumseh, ON
F-150 Lighting , Tesla Model Y
Please give us a like and subscribe. We'll be doing more Lightning videos in the future.
is there a way to hook up a line from the windshield washer to make the camera have the washer option ?
Thanks
BennyTheBeaver
Fyatrk
Christopher
Tecumseh, ON
My Pro had the washer housing already attached.
Any photos of what that looked like?
that’s all that is involved in the install?
Just splice into the washer line with that part from Tasco?
Thanks
BennyTheBeaver
Thanks
Yes, as long as your camera mount already has the housing for the washer attached like my Pro with front camera did. Otherwise, you need to get the housing as well. No photos of the housing unfortunately.
