How To Adjust Stock Headlight Beam Height
"wrecking" the engineering,
Yes, there is a reason that vehicles are designed the way they are. Suspension geometry is important. When you modify a vehicle because you think it looks good then it's vanity. We've all done it at some point.
I'm not here to knock your choices. You've got your reasons just make sure your headlights aren't blinding everyone.
Ford F-150 Lightning How To Adjust Stock Headlight Beam Height images
astrand1
Alex
Studio truck driver
I think that only the 22s had sensors. Parts shortages took that system off all the other trucks.
You dislike the look? Seriously? The factory rake on these trucks is ridiculous.
Well shit! Went out and looked on the front right I found this plug. I have a feeling this is for front level sensor. Me being the stock nerd that I am now will have to look into this further. My truck only had one deletion and that was the advanced security pack which I have since added back in for a whopping $38. lol.
Ford F-150 Lightning How To Adjust Stock Headlight Beam Height IMG_0469
Which is why it pointed out a wide variety of vehicles, including a Ford with near the exact same suspension, that FROM THE FACTORY is setup exactly like what a "leveling kit" does.
Literally, factory trucks, and from the factory comes with the front suspension at a geometry that is exactly the same as what folks are doing. That was the point for including those vehicles, not because they are "big truck looks cool" , but because they specifically use the factory suspension at a higher ride height, with no modifications to the geometry.
Which is why using the words like "WRECKING" is a lie designed only to push someones agenda. Especially when your example is NOTHING like what we are talking about. If your only point is to use extremes then you are not doing so for justifiable reasons.
I don't think you understand what the word vanity means. Which you yourself said you like to have the rake for loads, by your own argument there is no reason the back needs to be level, other than for looks. So by your own argument you liking the rake is because of vanity then. This is especially ironic from someone with a Lariat.
GingerBear85
2023 F-150 Lightning Lariat ER - Stone Metallic
Construction
From your profile it looks like we have the same truck... can you share the part you ordered to get back the deleted features and if you find this is the leveling connection for the lights the part you install to get them back?
astrand1
Alex
Studio truck driver
Let me get the part numbers together. I added the security back and added back the lighted cup holders. Both were pretty easy to do. And do me a favor and send me a dm so I don’t forget. I’m working on that front plug but I do get scatterbrained and might forget. lol.
digitaldad
2023 Lightning Lariat ER
I wasnt even aware of the auto-level headlights...the suspension shop today went to show me where these tie into the UAC (upper-control arm) sensor and that they "use the auto-level headlights" and of course I don't have them. They had just done a '24 Platinum that did have them.
Did anything ever come from this @astrand1 & @GingerBear85?
I had then thought maybe this was tied into the bed scale delete (that mine had) but the comment above seems to contradict that. So this would be more than a harness, right? Like an electric assembly on the back of the headlights?
GingerBear85
Construction
Haven't had time or funds to pursue the additions but hoping that @astrand1 has had the time to figure it out!
Tractionlimit
Ryan
2024 F150 Lightning Flash
I actually like the rake. Reminds me of some 1970s Mustangs with their rakes.
Well, to each their own... It does make me wonder if Ford added the rake to cater to the nostalgic 'old guys with money' set, leaving the rest of us to figure out how to level it for a more current look.
derelict
XLT ER
I personally hate the rake... I've leveled every truck I've had either by lifting the front if it was 4WD or dropping the rear if it was 2WD. But I leveled this truck (2.6" lift) and didn't need to adjust the headlights.
