NHTSA Recall - Loss of Steering from Front Control Arm Separation (Impacting certain 2023 to 2024 builds)
HOTAS
Lightning Flash, Tesla MY, Chevy Volt, PiPrius
Airbus Pilot
2024 Ranger had the exact same issue. Easy DIY if you have a torque wrench.
Andrewbens
Modesto
Lightning
Mechanic
now does anyone have specs on what the torque should be on this nut?
Cvh8601
2023 Lightning Lariat
Mine is a 12/23 build, and yikes! Passenger side had maybe 10 ft-lbf on it, driver more like 30.
Definitely don’t recommend relying on visual inspection!
PrimeRisk
Denver-Metro
Technonerd
Erm... I've got a quality torque wrench, but don't you have to hold the bolt (red arrow) so you can get the correct torque on the nut (black arrow)? Otherwise, isn't the thing is just going to spin?
To do this correctly do I put the torque wrench on the bolt and hold the nut with a box wrench?
Ford F-150 Lightning NHTSA Recall - Loss of Steering from Front Control Arm Separation (Impacting certain 2023 to 2024 builds) 1735753574210-nk
mrau
23 Lariat⚡ER
When torquing the bolt does the wheel have to be off the ground (jacked up) or on the ground?
Not sure if that matters or not.
rparry
Bob
F150 Lightning Flash Ordered Nov. 18th 2024
Ball Joints use a shallow angle taper that is self locking and should not require holding the indicated hex in this condition. A torque wrench that will allow you to hold that hex and torque is
going to be a special wrench. None of the torque wrenches I ever used in my days as a mechanic
were open at the top to allow this.
Brons2
Mij
Cybersecurity
Looking at the photos one can see how this is assembled at the factory.
There is a hex on the ball joint shaft that is held by the installation tool as
the nut is run down.
During my days as a Ford Mechanic, shortly after the earth cooled, Ball Joints
and Tierod ends used Castelated Nuts and cotter pins. There was a torque spec
but it did not matter as there was no guarantee that the cotter pin could be installed
at that torque. If the holes did not match, you Always tighten the nut never loosened
to install the cotter pin. This system was easily visually checked. Something the
current system can not be. I guess this is progress, but the older system was far more
fail resistant than this new system. The new system does not require as many humans
so possibly cheaper. If this system makes many of these errors it might not be cheaper!
I agree with this. A castelated nut and cotter pin would keep this from being an issue. Of course, you'd still want to tighten it down to spec, but, the cotter pin would keep it from completely coming apart in the short term.
They have made the torque on these nuts a single point of failure.
