Here's a screenshot of the menu that I am seeing with the below settings:
APIM 7D0-01-01 xxx9 xxxx xx--
DSP 783-01-01 xx1x xx--
Tapping either of them does nothing at all. No beeps or button interactions.
Any thoughts?
This was my experience with Beosonic as well. '22 Platinum
What does FORScan show as the part/strategy/configuration numbers for your DSP (see post 47)? You can use FORScan Windows or the free FORScan viewer app on your phone to see these numbers.
DSP - (Audio) Digital Signal Processing Module
Part number: ML3T-18B849-BK
Calibration level: ML3T-18B849-BK
Strategy : ML3T-14C589-BK
I have no idea what this means.
Scot Graham
Scot
Central Oregon
2024 F-150 Lightning XLT
Window sticker says I should have "Forward Sensing System" i.e. proximity sensors on front bumper. My last discussion regarding this problem was moved to another thread. I've broken out the old windows lap top, loaded up FORScan, bought a dongle and am ready to ruin my new truck. Can you tell me if I'm approaching this correctly.
First the wiring diagram shows all proximity sensors front, and rear all go to the IPMA module, so I looked over livinitup's spreadsheet dated this year and found the bottom tab for IPMA 2024. I started down looking for anything with the text "Cnfg_PA" thinking this would be all parameters associated with Parking Assist. It was basically all in 706-02-01. Still pretty opaque, but I compared it to my As-Built Data to see if I could make some sense of it. I came away pretty confused. I guess I'm looking for a methodical approach to discover how to recognize the sensors and enable the features and I feel more like I'm about to become a monkey banging on a typewriter. I feel pretty confident I could perform the actions others have discovered, but I think this may be virgin territory (adding front sensors). I did read the thread of the fellow who added radar, etc, so I'll go re read that. Can someone point me in the right direction.
carys98
Cary
Raleigh, NC
2023 Lightning Lariat SR
One thing Iโ€™ve noticed is that all Lightnings have 4 sensors on the front and rear bumpers but those with Bluecruise and parking assist have two additional sensors on the sides of the bumpers. Park assist may require those.
Ford F-150 Lightning F150 Lightning FORScan thread - Version 2 IMG_0618
tnugentfl
palm coast, fl
2023 f150 lightning lariat ext range
I want to go ahead and do the matrix headlights but I already have the BC updates that allow in lane positioning and assisted lane change. I made the FORscan changes to give me the menu options. Does this interfere with the matrix upgrade? I read somewhere it does.
Also. Once I do the matrix changes do you have to do a headlight calibration or something?
Thank you!
