FLSpartan04
Daryl
23 F150 Lightning XLT ER
check that you have the connectors for the new style harness. Comma redesigned about 2 months ago. Pins are the same but connector is different.
Just ordered the new white connectors. I think everything else is the same (hopefully).
FLSpartan04
Daryl
OBD just keeps device powered between drives. if you don’t mind waiting on it to boot every time you can omit it.
I just got mine plugged in finally, doesn’t seem to boot without the OBD plugged in. No blue led or anything. It does boot with the OBD plugged. I wonder if they made a change?
Ajzride
Alan
Houston
Eng
No. if it’s not booting when the truck cranks then it’s not getting 12v through the USB cable, which is an issue. It won’t be able to detect when the vehicle starts a drive.
FLSpartan04
Daryl
Interesting. This is the same guy from the discord in a panic (which you probably deduced by now). I wonder if something is wrong with my Q4 or comma? This test was done without the extension, so only comma components. This may tie into my other problems. I’ll take some videos when I get time to play with it and share them on the Discord. Thanks as always!
FLSpartan04
Daryl
Turns out I stink at crimping those tiny pins. It I keep trying, I’m going to use them al up, and they are on back order. Anyone willing to make up the extension harness for me? I’ll ship all my materials, and pay for your time. Also will throw in a set of tow hook covers! 😉
linuxgangster
shane
2023 F150 Lightning xlt
Just curious if anyone here has a Pro or XLT, added ACC and can confirm SunnyPilot of BluePilot work?
Ajzride
Alan
Houston
Eng
Can confirm it works once you add ACC. Been a few guys to do it, including some not on here.
BennyTheBeaver
Only on 2022, 2023 models. 2024 doesn't work. I use BluePilot on my XLT ER and love it.
linuxgangster
shane
Awesome thanks! And I have a 2023 so I should be good to go. I first need to install ACC ;)
dr1983
dennis
2022 Ford Lightning XLT
Security Advisor
Hit up Aj. If he is unable let me know.
Would you be able to make a harness for the Comma? I have a 22 xlt with lane keep but not ACC. I do have forscan if that helps
Ajzride
Alan
Houston
Eng
You do still need the extension. I don’t really have any time until May to do one, but there is a guy on discord who said he was interested. I’ll ask him what he charges.
have you already ordered your ACC parts?
Also comma has been shipping a lot of the v1 harnesses lately, so I guess no one needs to buy extension components until they get the harness and see if it’s a v1 or v2
