2023 ER Lariat Heater Went Out Just as Winter Hit
Adventureboy
I've had to add coolant to both my Lightning and my wife's MME. Both were right at the bottom and I expect there is a safety switch that won't allow the heater to kick on if the coolant is low, so I agree with checking that first.
Karlos
Karl
DFW & Kerrville Tx
Retired CPA, active pilot
You'd think there would be a low coolant warning/message display ??
  • Sad
cal
Cal
Battle Ground WA
2022 Lightning, Tesla Model S Plaid
Just had a thought...purchase an electric space heater...maybe it will be more efficient than the native heater...
Great recommendation we used space heaters in Alaska to prevent plastic interior cracking in the winter. They work great didn't really heat anything at 40 below but it did prevent cracking
Adventureboy
You would think. No warnings on either of mine and the Lightning tank was pretty much empty. Given @Buio and @chrisvitek1 's experience, it doesn't appear to have a low coolant warning system, unless you consider a non-functioning heater as the warning. :)
I have it on my weekly watch list along with topping up the washer fluid. It's easy to glance at it in the Lightning when the Frunk is open. Not so easy on the MME as I need to remove a trim panel. I haven't had to add to either since the first time.
YellowstoneLightning
Torrey
Montana
2023 Lightning Lariat Extended Range
Update for those who have been following along: I checked the coolant and you were all right, it was very low; below the min mark. I refilled it to a little below the max line and tried the heat--that didn't work. Next, I disconnected the 12v for 10 minutes then tried again--still no heat. Looks like I'll have to take it in to the dealer after all. Thanks to everyone for your input.
If it was very low, there could be airlocks in the system. If so, driving should eventually work them out, but you’ll need to keep adding coolant as they do.
ETA - Have you had battery modules replaced? Several on here have reported improper coolant refill after such a service.
Torrey
Montana
No battery modules replaced. This is the first real problem I've had with the truck.
Scorpio3d
SS/IBA car wash owner
I have the same model year and vehicle as you.
I had to add coolant after a couple months of ownership. Probably need to check mine again.
Hope you get it figured out and/or fixed.
