jybell
Houston, TX
18’ Raptor / 23’ Lightning Lariat ER (bld: 1/2/23)
Best to look at drivers door pillar sticker. 22’s & 23’s came with two tire brands. This led to a TSB from Ford when they discovered many trucks with 116T tire ratings and 42PSI marked on pillar, had the TPMS set to 36PSI. The 36PSI tire pressure is correct for 115T rated tires, but an issue for 116T rated tires. Due to the higher load rating on 116T tires, I think this yields a better result than 115T at 36PSI. You will have less rolling resistanc, but if you switch from what your truck is marked, I suggest having local dealership set TPMS to the corrected value and updating door pillar for the next possible owner.
I have a ‘23 Lariat originally fitted with the 115T 36psi, but I just switched to Michelin LTX MS2 116H rating.
Should I be filling to 42 for the higher 116 load ratings? Now I’m really confused lol
I would fill it to at least 42. I have my Generals at 46 and Ford recommends I have them at 42.
Reactions: N87
Mike G
N. AL, USA
Noise is the most important tire variable to me; should I buy Toyos?
Compared to the original tires...which I really never heard at all, there is now noticeable tire whine and is the one downside to installing these. The whine is worse when they're new though. I've gotten used to it, and it's not as noisy as some of the trucks I'm passing on the highway that you can hear from a quarter of a mile away.
Chriseberle
F150 Lightning SR Tesla Model X
I didn’t get those. That’s the E load for those looking to rock crawl. Stiffer sidewall etc. 116T XL is a direct replacement for the OEMs. Light off-roading. Same ride. Same PSI. You are swapping the high efficiency for all terrain tread. E tire reduces range 10-15%. 116T XL about 5%.
I have the E rated Toyo Open Country III EV tires and this is just not true at all. I run about 45 psi in these tires and the range loss is about 5% from the stock tires. I have about 8000 mile on them so far.
Nikola 369
Pella, IA
2022 F150 lightning Lariat SR
Sales Engineer
The answer isn’t so straightforwar. Yes, should be higher ( at 42 cold ) but more importantly need to have dealership set TPMS up to the 42 rating. Then you need to mark the driver post with updated info for the change. This is important for you and others. If this step isn’t followed, likely anyone servicing tires or performing rotation will set pressure to lower rating based on pillar and computer if it’s a ford dealership. Another important item, if you want TPMS to work, it needs changed. The system is setup to show a low tire notice with a 5 PSI lower than set point. This will now take 11 PSI to react if not updated. It’s all in what your goal is. I’m trying to keep truck as close to stock as it ages. I like the lower rolling resistance of the 116T rating and I don’t think it rides bad because of them. The reason I know what this issue is my truck was one of the many shipped setup for 115T tires but had the 116T installed by ford assembly plant, as well as the corresponding pillar label matching tires. I had a nail cause a tire to drop pressure and TPMS never went off. I hadn’t noticed and it went to its first service. The tech told me 3 of the 4 were set at. 45PSI and the last was at 36PSI. They noticed during rotation the tire looked a little low, so when they were done were resetting all the pressures and found the low tire and nail. It was all fixed when I picked it up, but took longer than normal. They were concerned TPMS hadn’t worked as intended and investigated it and reached out to Ford. After direction from BEV team, issue was corrected. I recieved the recall/ TSB in mail about 4 months later.
deltalightning
Andy
NE Louisiana
2024 Lightning
Help me understand the range impact here and how it could impact planning on a trip.
since the tires are larger and I’m traveling further per rotation, the range estimate shown on the truck should be LOW, correct? I should be able to travel further than the truck thinks (actual miles).
And to confirm, using Forscan to adjust the tire size setting should get this back to ‘factory’ calculations?
TIA
jybell
Houston, TX
Any idea if the TPMS update could be done via Forscan?
Nikola 369
Pella, IA
Sales Engineer
I don’t know what the dealership used, sorry. I know they updated two different modules to fix the issue. The first one was straightforwar, just like ice trucks. The second was at BEV team request and that fix the issue. Only doing the first correct PSI set point, but if air was let out of tire still wouldn’t set alarm on dash. The second module updated corrected that issue.
Nikola 369
Pella, IA
Sales Engineer
TIA
The GOM will self correct after a few trips. I think it’s combination of miles traveled and number of ignition starts. This way it can only correct so much at a time, keeps it from very suddenly being very far off. I’m not sure about changing tire size with Forscan, I believe what ever you do, the GOM will catchup at some point.
XLT Jeffy
Vancouver, BC
2022 Ford Lightning XLT SR
Thanks for all the info so far. Interested to hear more reviews about snow/ice performance as I'm considering these all year round instead of swapping to Blizzaks every winter.
WoodduckMN
Andover, MN
23 Tesla Y, 22 Lightning Lariat, 21 Chevy Bolt, 13 Ford Explorer
Manager
I have the E rated 123s since last October, I run them at 50-55psi. This week when it was slightly above freezing I’m getting 2.0. Kw/mile.
JerseyMike
Allentown, NJ
2022 Ford Lightning Lariat SR, 2" pucks, P275/65/20 Nitto Recon
TIA
that is correct, I have 275/65/20 Nitto tires...for that size you need to set the speedo in for scan to 2631. (stock will be 2547 if you have 275/60/20)
you do this in forscan and it will correct speedo, miles, and range estimates
Mike G
N. AL, USA
The "Recommended Tire Pressure" shown in the IPC is an asbuilt value in the BCM. I'm not aware of anything that dealer techs can do using FDRS to change that value. It can be adjusted however using FORSCAN pretty easily. It is important to adjust the value so that the 'alert range' for low pressure warning will be correct for the installed tires. That's why there was the FSA/TSB/Recall (and an OTA for the BCM) that corrected that value back in 2022 for those trucks, as it was deemed a safety issue.
