I'm quite jealous of these trips. I'm itching to take a multiday journey but I have the typical excuse of limited time off work and wife has other ideas. Hope the recovery goes well.
Magendi
Philly area
Lightning Lariat
I should add that I experienced some other new things on this trip. Limited power availability due to cold battery - as low as 78% power, very often 91% power. That was a new one for me.
I've been seeing the same of late but when I step on the pedal I can't say I feel power lacking. It serves mostly to remind me to try to not hammer so much on the accelerator if I don't want to stop to charge.
Great writeup! One question: why not let the truck cold soak then charge first thing in the morning? A DC fast charger is a pretty effective way to warm up the battery so that first leg is more efficient. I suspect it might end up saving time over charging the night before and might be better for the battery long term to get cold overnight when at a lower state of charge (so long as it's not so low that you can't limp to the nearest fast charger).
1) By charging at night, the battery is already warm from driving, so the charging session is faster.
2) When on a trip, I'd rather check in the hotel, eat dinner, and then go charge and go to bed versus spending 45 minutes tomorrow morning charging when I want to be on the road.
3) Similarly, when going to a ski area, we're up at 6, eating at 6:30 or 7 (depending on hotel schedule), leaving at 8:15, and on the slopes as close to 9 as we can get. Taking 45 minutes to charge isn't part of the plan.
4) Location of fast charger might have been 20 miles before the hotel exit.
5) Unless range matters, that first leg that's impacted by efficiency (cold battery) doesn't impact TIME. You still drive 50 miles in the same amount of time. Had I had one of the 150 mile legs, I probably would have gone to a fast charger to warm up the battery before starting that leg.
Eboss
Eric
Detroit, MI
2023 Ford Lightning Lariat, 2021 Tesla Model Y LR
Do you really find that the Google maps predicted SOC at destination doesn't match what the truck is saying?
I've done a few 100+ mile trips using Google maps and i was concerned about that. I kept an eye on the Google prediction and the actual truck info and they seemed to me that they were matching pretty well.
That would be a total disappointment since the Google navigation is a huge upgrade over the terrible, embarrassingly awful Ford system. Did I mention the Ford system is awful? :)
They were so far off that I sent feedback at least twice.
B177y
Olympic Peninsula WA
www.ptcoffee.com
2024 Lightning Pro ER Max Tow
Coffee Roasting
Without an OBD adapter and Car Scanner, doing trips like this isn't for the faint of heart. Using Ford's Navigation and instrumentation is risky. Even using GoogleMaps with Android Auto doesn't work well, as it projects an end of trip SOC% that doesn't match what the vehicle says on the instrument panel.
For my clarification, are you saying that you did you use ABRP with an OBD for this trip?
I did a similar length trip through WA, ID, MT and ND and found that the ABRP/OBD was the best, easiest, most accurate for me. It was late fall, so the weather was warmer.
I agree with your answer above to @Eboss , Google Maps wasn't as user friendly and I didn't like the inability to plan ahead. The charger suggestions were sometimes really random even with a reliable Tesla or close by EA much easier to access on my route.
I *WANT* to like and use the Ford nav, but it is basically useless in it's current iteration without the Tesla charger integration.
No. I used Car scanner with OBD and free ABRP.
Joneii
Central PA
F-150 Lightning, Tesla MY
While getting reduced power indications for cold batteries makes sense, keep your eyes on it. I started getting reduced power indications even when the battery wasn’t cold. I thought this unusual because I had only ever seen it at really low SoC or with a cold battery.
Then I started seeing 93% power with 51% SOC and a battery indicating normal temps. Well, I didn’t worry much because 93% of 585 hp is still a shit ton. A few months later and my favorite vehicle is now at the dealer getting a battery module replaced. Looking back on it, I suspect these seemingly pointless power reductions were my first indicators and they began on a few thousand mile multi-day towing road trip.
I hope I’m wrong, but keep your guard up
Already had some modules replaced last year.
3rdgenfan
Geoff
Delaware
Did some damage on my mid-back on a fall while skiing 10 or so years ago that still crops up to this day, basically faceplanted and the spine went the wrong way. Hopefully the recovery is quick!
Power P
Shoreline, WA
2024 F-150 Lariat ER - Antimatter Blue, 2024 Volvo XC-60 T8 PHEV
Great write up, Rick. Thanks for sharing...I too did a trip to the mountains in my new F-150 Lariat last weekend (Seattle to Lake Wenatchee and then back to Steven's Pass resort) and the truck's range held up pretty well all considering the low temps (mostly in the teens from the pass East). I largely coasted back down the mountain Route 2 into Sultan for a high speed charge at an EVCS station coincidentally co-located at a Chevron! Pretty impressed with the truck so far...
I'm curious which OBD tool you'd recommend as I'm considering getting this and ABRP going on my next longer trip to Whistler next week. Like many in this forum, I don't trust the native SOC, and am looking for more (better) insight into range. I'll be hitting Tesla chargers on my trip north soon. That should be an adventure in itself too.
Thanks again for sharing your story!
OBDLink CX
