If I Recall CorrectlyI still don’t know what IIRC is supposed to stand for everything else I figured out out of context![]()
Isn't that a Camaro from the 80s?I still don’t know what IIRC is supposed to stand for everything else I figured out out of context![]()
What does "76YO" mean?I suggest that we need a glossary of acronyms. As a 76YO owner I get lost in some posts due to all the letters meaning ?? Meantime I’m lovin my 24 Platinum.
AA | Android Auto |
ABRP | A Better Route Planner (app/website) |
ABS | Anti-lock Brake System |
ACCM | Air Condition Control Module |
ACM | Audio Control Module |
ACP | Apple Car Play |
ADAS | Advanced Driver-Assistance Systems |
APIM | Accessory Protocol Interface Module |
APN | Access Point Name |
B&O | Bang and Olufsen |
BC | BlueCruise |
BCHF | BlueCruise Hands Free (Less Commonly HFBC) |
BCCM | Battery Charging Control Module |
BCM | Body Control Module |
BCMC | Body Control Module (C) |
BECM | Battery Energy Control Module |
BEV | Battery Electric Vehicle |
BJB | Battery Junction Box |
BMS | Battery Management System |
CAN | Controller Area Network |
CCM | Cruise Control Module |
CMR | Camera Module Rear |
CR1 | California Route 1 (also Rt 1) |
DCDC | Direct current (DC) to DC; for example, when changing DC voltages |
DCFC | DC Fast Charger |
DCM(E-H) | Door Control Module E,F,G,H |
DDM | Drivers Door Module |
DLC | Downloadable Content |
DMG | Dark Matter Gray |
DSM | Driver Seat Module |
DSMC | Driver Status Monitor Camera |
DSP | Digital Signal Processing |
DTC | Diagnostic Troubleshooting Code |
EA | Electrify America |
EAP | Early Access Program |
ECU | Electronic Control Unit |
ER | Extended Range battery |
ESCL | Electronic Steering Column Lock |
ESP | Extended Service Plan |
EV | Electric Vehicle |
EVSE | EV Supply Equipment (Charger) |
FCSP | Ford Charge Station Pro |
FCTP | Ford Courtesy Transportation Program |
FDRS | Ford Diagnosis and Repair System |
FE | First Edition |
FSA | Field Service Action |
FSCM | Five Second Control Module |
FTRM | Front Trunk Release |
GB | Grabber Blue |
GFM | Generic Function Module (on a Mach-E this is the Frunk control module) |
GOM | Guess-O-Meter. The estimated range remaining displayed by the vehicle. |
GSM | Gear Shift Module |
GT | Grand Touring (from Gran Turismo) |
GTPE | Grand Touring Performance Edition (also GT-PE) |
GWM | Gateway Module |
HBPSM | High Voltage Battery Pack Sensor Module |
HCM | Heating (Headlamp?) Control Module |
HFBC | Hands Free Blue Cruise |
HVAC | Heating, ventilation, and air conditioning |
HVB | High Voltage Battery (as opposed to the LVB 12 Volt battery) |
HVBJB | High Voltage Battery Junction Box |
IB | Infinite Blue |
ICE | Internal Combustion Engine; or, what one puts in the frunk to keep cold things cold. ICE'ing is when a ICE vehicle intentionally blocks a BEV charging station or when a BEV is parked at a charging station but not charging. |
IPC | Instrument Panel Cluster |
IPMA | Image Processing Module(A) |
LFP | Lithium Iron Phosphate (battery technology) |
LVB | Low Voltage Battery (the 12 volt battery) |
MME | Mustang Mach-E |
M3 / MS / MX / MY | Tesla Model 3 / S / X / Y |
MY | Model Year (e.g. MY22 for Model Year 2022) |
NMC | Nickel Manganese Cobalt (battery technology) |
NVLW | New Vehicle Limited Warranty |
OASIS | Online Automotive Service Information System |
OBCC | Off Board Charger Control |
OBD-II or OBD2 | OnBoard Diagnostics version 2 |
OCPP | Open Charge Point Protocol |
OCS | Occupant Classification System |
OTA | Over The Air |
PAAK | Phone as a Key |
PACM | Pedestrian Alert Control Module |
PCM | Powertrain Control Module |
PDM | Power Distribution Module or Passenger Door Module |
PDR | Paintless Dent Repair |
PHEV | Plug-in Hybrid EV |
PSCM | Power Steering Control Module |
PTC | Positive Temperature Coefficient heater (thermistor resistance incr with incr temperature) |
PTS | Professional Technician System - Service Information (available to ford service departments) |
PU | Priority Update |
RCM | Restraints Control Module |
RFA | Remote Function Actuator Module (Bluetooth Module) |
RGTM | Rear Gate/Trunk Module |
RTFM | Read The "Ford" Manual |
SCCM | Steering Column Control Module |
SOBDM | Secondary On-Board Diagnostic Control Module |
SOC | State Of Charge |
SODCMC | Side Obstacle Detection Control Module C |
SODCMD | Side Obstacle Detection Control Module D |
SODL | Side Obstacle Detection Control Module, Left |
SODR | Side Obstacle Detection Control Module, Right |
SPW | Service Parts Warranty |
SR | Standard Range battery |
SSM | Special Service Message |
SSN | Stop Safely Now |
SSP | Special Service Part |
SVS | Service Vehicle Soon |
TCU | Telematics Control Unit |
TIM | Thermal Interface Material |
TLA | Three letter acronym or Top Level Assembly |
TPMS | Tire Pressure Monitoring System |
TSB | Technical Service Bulletin |
USB | Universal Serial Bus |
UWB | Ultra-Wideband (the future of PAAK) |
VDM | Vehicle Dynamics Control Module (GT, GT-PE only) |
WACM | Wireless Accessory (Phone) Charger |
WAP | Wireless App Projection |
WOT | Wide Open Throttle |
WSM | Workshop Manual |
