richguy82
Richard
2023 Ford Lightning Lariat
I still can't get mine to work that way. I have it enabled everywhere and still nothing
I actually made a mistake in saying it was 3 changes in that photo. It’s actually 4. The “Global Close Vehicle” should also be enabled. There are 3 other modules DDM, PDM, and APIM that also require updates. I believe it was just Global Windows Open and Global Windows Closed for each of those 3 modules.
MJFlanigan
Michael
Atlanta, GA
2023 Ford F-150 Lighting XLT
I did all those and couldnt get it to work still.
richguy82
Richard
Might want to go in and make the changes “As Built”. When I made the changes in the text version I went back to look at “As Built” for each module and the values matched up perfectly with the reported values on page 1. Hopefully that works out for you. Sorry I can’t be of more help. There are much more qualified people on here than me that I’m sure would be happy to assist.
MJFlanigan
Michael
Atlanta, GA
Appreciate the help I'll try it again.
richguy82
Richard
Just to clarify, I originally made the changes in the text mode for the first 3 modules and used the codes in “As Built” for BCM. The photo was me recording the values I saw that had changed, but I had only filtered for “Global”. I suppose it’s possible other changes occurred that I didn’t see. I mean, I made 3 changes in BCM AS BUILT, but there are at least 4 changes when I viewed in text. Hopefully that makes sense.
Fistandantilus
2023 F150 Lightning Platinum
Hello, ist there any update on how to keep the power in the bed on while the truck is off just like the newer 2024 trucks.
F.
Andrewbens
Modesto
Lightning
Mechanic
F.
I believe you go to settings than vehicle and than turn off 30min count down.
