Leak on rear motor
Keanen
Keanen
MN
2023 F-150 Lightning
Software Engineering
Hey all, I brought my truck in for a recall item, and they found a leak during the inspection. Using search, I did not find any like issues. Has anyone else seen this issue? I'm concerned this could become a big issue as they look to start working on it next week. Thanks!
Ford F-150 Lightning Leak on rear motor Screenshot 2025-03-01 at 8.24.25 AM
Could be o'rings, oil pump, oil filter, axle output seal, or electronic interface plug
Ford F-150 Lightning Leak on rear motor 1740840339110-lo
Ford F-150 Lightning Leak on rear motor 1740840219233-m0
Keanen
Keanen
Keanen
MN
Thank you. I will update when I hear back.
Viewpapa
Rick
2023 lightning
I have a 23 Lariat ER. My dealer found a weeping seal on the rear motor(not sure which one) last fall. It took over a month to receive the part, but only a couple hours to replace. The dealer told me it was not a common issue in our area, at the time.
Take a look at the work order, I'm curious which part or seal was replaced.
Keanen
Keanen
Keanen
MN
Here is an update on the issue here. The problem was a leak from the seal on the oil pump on the rear motor. They ordered the part, replaced it, and refilled the oil. I'll report back if there are further issues.
MountainAlive
Massachusetts, USA
2023 F-150 Lighting ER 512A Max Tow
Glad to hear this sounds like a pretty straightforward repair. No need to pull the whole motor out it sounds like.
Whammy Bar
Kinda cool to be one of the few Lightnings that's had an oil change...
Keanen
Keanen
Keanen
MN
I must say, I was a bit confused when the term "oil pump" came up.
HOTAS
Lightning Flash, Tesla MY, Chevy Volt, PiPrius
Airbus Pilot
Tesla motors are the same, oil pump and oil filter.
It’s really a Dexron VI type ATF fluid.
Drayday55
Andre
San Diego
22 Lariat Lightning
Contractor
Hey. Found a bunch of oil on my front bumper tonight. Trying to understand it a bit. Does to oil smell like ATF only slightly less strong?
Yes
