Repeated Alignment Issues on 2024 F-150 Lightning – Anyone Else?
boltandcece
Dan
I’ve got a 2024 F-150 Lightning (~1,400 miles) that’s experiencing a recurring alignment issue that has two different Ford dealers stumped.
The Issue:
• At just 300 miles, the truck had a hard pull to the right that needed constant correction.
• First alignment showed rear toe was well out of factory spec from the factory.
• Now at 1,400 miles, after two dealer alignments, rear toe keeps drifting out of spec, even within 40-60 miles of normal driving.
• The truck also pulls hard right or left under acceleration, much more than what I’d expect for normal AWD torque steer.
Dealers’ Response:
• Both have checked all suspension components and say everything is “tight.”
• They realign it, but within a few drives, alignment shifts again.
• No clear answer yet on what is allowing rear toe to move repeatedly.
Could This Be a Design Issue?
• The weight (~7,000-8,000 lbs) and 775 lb-ft torque put extreme stress on the suspension.
• Could this be bushing deflection, rear subframe shifting, or toe links not holding position?
• Or is this just a one-off issue with my truck?
I love the truck, but if Ford doesn’t figure this out, it’s looking like a Lemon Law case. Anyone else experiencing this? Would appreciate any insight!
l!ghtning
U.S.
24 Flash
24 Flash, ~800 miles, literally just noticed an odd pulling to the left at street speeds. Didn't know I could take it to dealer for this.... is it covered under warranty?
boltandcece
Dan
This is the first time I’ve seen this reported here. If it were a design issue, we’d have heard about it by now. The dealer needs to get Ford involved.
Totally agree, and that’s exactly what I plan to push for after tomorrow. Just spoke with the service advisor this evening, and he’d like me to come in tomorrow for a test drive with the lead tech to demonstrate the pull I feel to the left and right under load.
At this point, I see that as secondary because steering feel can shift based on conditions and as the alignment moves. The bigger concern is that I have alignment readouts from three different dealer visits showing measurable movement—with rear toe drifting out of spec twice.
Another layer of concern is the upper control arm recall for improper torque, which raises questions about whether other suspension components could have also left the factory under-torqued. If that’s the case, it could explain why alignment isn’t holding properly.
Depending on how tomorrow goes, I’ll push for a Ford field engineer to be involved because while the techs say everything is “tight,” it’s hard to confirm whether torque was actually checked across the board. Something is allowing alignment to shift, and it needs to be properly investigated.
boltandcece
Dan
Yes, at that mileage, the dealer should inspect it under a customer service-type inspection at minimum. If the vehicle is out of alignment, and the alignment isn’t in factory spec, and you haven’t hit anything (potholes, curbs, etc.), then the inspection and necessary alignment should be covered under warranty.
In my case, I’ve had multiple inspections and alignments at two different dealers, and I haven’t been charged for any of them because the misalignment happened without any external cause within just a few hundred miles.
One thing to keep in mind—there’s a known recall for upper control arms that were improperly torqued from the factory, which adds another variable to this issue. If alignment is shifting unexpectedly, there’s a possibility that other suspension components in some build ranges may have also been affected. That recall did impact some 2024 builds and just something to be mindful of.
Definitely take yours in and have them document everything, especially if the pull is noticeable. If they find it out of spec without any external impact, it should be covered.
Theres your problem. Why is it going out of spec though? Align, torque and mark all the components then drive it to see which one is the problem.
You gotta hold on to the reins when you're gettin on the ponies.
jetfixr1
Manny
Atlanta
2023 F150 Lightning Lariat ER
Get it realigned and put torque seal on everything. When it happens again you will know whats causing it.
boltandcece
Dan
Great idea, and something I will push the dealer on. You’re spot on. Standard practice for many aircraft fasteners anyway. Photo checks out. :)
