Heating - Temperature Adjustment
Timeless Epoch
Chad
2024 F150 Lightning Platinum
Professionally: Disaster Recovery - Recreationally: Watchmaker
My 2012 Lariat and 2017 Platinum F150 were always rock solid with the Auto Temp setting. I pretty much them both on 70 all year and it took care of everything.
I did notice on cold days, my Lightening it always seems to blow cold (like AC cold, not just unheated) out of the dash vents for the first 10 minutes, unless I crank the temperature above 75F. Things seem to return to normal and 70-72F is a reasonable setting after about 10 min.
Wendy
Puget Sound
1967 Saab 96 (dead), Silverado (squished), F150 L
Everyone is welcome here, whether you talk C or F. Frankly, we should have gone to Metric when they started teaching it in the US in school in the 60s. Why do we need to think about 12-per or 16-per or how many ounces a tablespoon of water weighs at 32 degrees?
I always wonder about my friend who jumps in the car and either turns it to 90' or 60' depending upon whether he wants to get warmer or cooler. As noted above your furnace raises the temperature of the air by (let's say 20') and pumps out that air until the ambient temperature reaches what you have set it to. You don't really want it to be 90, you just want to warm up. Set it at 70 and it will stop when it reaches that temp. It will push the warmest air possible until it gets you to where you have asked to be.
GoodSam
Good
occupying space
Auto is great. It's like my house, set a temp and don't think about it anymore. This is close to the best auto system I have had.
Auto does not seem to function that well for me. I often need to set the temperature to above (77F) or below (68F) to get ~72F that I like, depending on outside temperature.
I also wish that the three fan speeds available in Auto would correspond to the fan speed range available when in Manual fan control, that is, Manual fan speed seems to have maybe 7 speeds and the Manual top speed is much more powerful than the top speed in Auto.
I find that the speed is more aggressive (faster on III) when the cabin temperature and desired temperature are far apart, be it cold or hot season, as the disparity decreases the fan rate automatically slows to a minimum rate.
GoodSam
Good
occupying space
And I think the air flow to the window side vents is too weak compared to the center vents, but maybe Ford has determined that the HVAC works best that way. I think adding heat blocking ceramic coatings to the windows helps a bunch to alleviate the need for window air flow. However, I am still not satisfied with the operation of the HVAC.
When not on Auto, is the system still trying to match the set temperatures? I interpreted some of the remarks that that may be the case, altho' that would not seem to make sense.
I think the temperature is still moderated by activating the PTC heat or AC cycle depending on the situation, you're just getting more or less air flow according to how you manage the fan speed and outlet selection.
Think of it as Auto, and Semi-Auto.
If you set one specific item manually the system is no longer fully automatic, but it is not completely manual either. If you manually change the air location from floor to dash vents, you likely still want it to manage temp. If you did not specifically set a fan speed the fan speed is still automatic.
If you set an item manually, that one item will stay there, however all others will still be managed automatically.
Altivec
The problem I am having with keeping the heating on auto on cold days is window fog up. Yes... I have the A/C on. I've had numerous F150's and when on auto, a tiny bit of air was always directed to the windshield and side windows. That prevented things from fogging up. In the lightning, once the cabin heats up in auto, the air gets directed to the floor and completely shuts off the defroster. Every 5-10 minutes, I need to switch the max defrost and then switch back to auto so I don't roast. As I said, never experienced this in any other F150.
This afternoon, I was tinkering with the AUTO setting button and it's impact on fan speed, we've noticed in the past the AUTO-2 was more reactive and under certain conditions might cause a higher fan speed than AUTO-3, counter intuitive right?!?
Back story, the temp was at 62 which I had lowered from earlier in the day at the close of a long 170 mile road trip, battery was low at 15% {running hard & fast} I wanted to ensure I could get home without stopping for a charge so I went spartan chilly
Made it home OK, then when we went out a couple hours later for a short ride that 15% was fine to make, but the cabin was cold and raw, I forgot to remote start, so I put it in AUTO-2, jacked up temp from 62 to where I normally keep it around 75, then 80, interestingly the fan speeds increased systematically without actually dialing up the fan speed manually.
I repeated this process on AUTO-3, there was no increase of speed until I hit the HI point setting, then the fan increased in speed, same process with AUTO-1.
So, I suspect the dynamic algorithm is failing in AUTO-1 and AUTO-3, @Ford Motor Company , let's get that fixed!
I propose an alternate hypothesis.
The three auto settings don't work as increasing or decreasing intensity, they work as three different techniques to achieve a similar goal.
Hypothetically, since I have not direct knowledge here, the following could be techniques used.
Perhaps
Auto 1 uses varying locations of air. Instead of changing fan speed or air temp, auto 1 is biased towards varying air location, blowing more directly on the driver when needed in order to make the driver feel the correct temp more rapidly.
Auto 2 changes the fan speed, moving more air to achieve the results of the driver feeling the temp changes. When the truck needs to heat, it uses air volume to put BTUs into the cabin, aka faster fan speed and more air flowing.
Auto 3 uses air TEMP to achieve the results. Fan speed won change much, but the temp of the air varies more than in the other settings. Lower amounts of hotter air, etc.
There are a wide variety of ways to make a driver "feel" a certain temp, not all of them involve blowing air harder. It's entirely possible the three auto settings are A, B, and C, not soft, medium, hard.
Perhaps
Maybe, get out there and do some testing LOL
Maybe better documentation by @Ford Motor Company could shed light on the methods of their madness.
GarageMahal
JT
Data Wrangler
This is my experience as well. I find this to be the worst automatic climate control I have had in decades due to the window fog. I have dialed in a manual setting that does a much better job keeping the windows clear but it isnt perfect either.
Scorpio3d
SS/IBA car wash owner
Pretty much I leave mine on (I guess y’all are calling it auto three)basically three lighted bars on the auto setting. The only thing I adjust is the temperature setting or completely turn it off. I generally precondition in the winter and keep it around 76°F –78°F. Summertime I keep it between 74°F – 76°F.
I did the same thing in my last five vehicles, and it generally takes care of the fog and keeps me comfortable.
