sotek2345
- First Name
- Tom
- Jun 7, 2021
- Upstate NY
- 2022 Lightning Lariat ER, 2021 Mach-e GT
- Occupation
- Engineering Manager
Per the e-mail survey that was sent around, the Max towing package is just additional cooling for the battery (edit: and motors) to support the higher sustained loads.It's true that batteries' internal resistance changes at different temperatures, but to a point, a warmer battery will have less resistance and charge "easier" than a cold battery. Also, the additional cooling on the towing package wouldn't be needed to cool a battery. If the stock cooling system can't cool a charging battery adequately, it will be completely overwhelmed by the truck driving down the road. The BMS would be the same between the trucks.
On a side note, I'm not even sure what the max towing package includes on the Lightning over the tow tech package.
