Did OTA 10.3.0 Remove Charging Locations?
If you received OTA 10.3.0 did you lose charging locations?
  • Total voters
Yzlvr
Eric
Thousand Oaks, CA
22 Lightning Lariat ER
I was just able to set a charge location. So last night I set a one time charge in the truck, so maybe it needed to do a complete charge before it lets you add the location? Since the update I have not been able to. Maybe ford did something in the backend?
sd25
NJ
F-150 Lightning Lariat ER, Rivian R1T
Received update but install fails due to "low 12v" battery. Not going to answer the poll, just putting that data point out there.
I had this happen the first time it tried to install 10.3.0.
Plugged it into the charger and then the update succeeded - seems like actively charging helps keep the 12v topped up better.
klossfam
Jeff
East Amherst, NY
2022 Lightning Lariat & 2022 Hyundai Ioniq 5 Ltd
Guys, which version of Fordpass and platform (iOS or Android) are you running?
FordPass 5.11.0 & Android 14 (Samsung One UI version 6.1 since a lot of people will have Samsung with Verizon as the carrier)
lex
Jason
2022 F150 Lightning
Maddening. Even after I charge again, no recognition of location. I have charge history in the app, but ZERO charging locations to choose from to set schedule or charge level.
Nothing in the truck or the app.
IOS 5.11
I don't have 10.3.0 yet, last update was 10.1.0.
I wanted to confirm that Fordpass 5.10.1 Android isn't the issue some of you are having, it's definitely the 10.3.0 update to the truck.
Confirmed that I could build a charging scheme at a new location, our local high school has 6kw level-2 facilities spread around the campus, I plugged in, and let the session run, I tried immediately adding a new charging location, it refused, telling me I needed to complete a charging session at the location.
Waited about 10 minutes, then tried to add again, while the session was still active, it worked, I was able to create a SOC limitation and save to Fordpass, a second or so later it displayed on the Sync screen
Ford F-150 Lightning Did OTA 10.3.0 Remove Charging Locations? 1738115181348-2e
Ford F-150 Lightning Did OTA 10.3.0 Remove Charging Locations? 1738115247040-kt
Slow & cold session 3% that I burned off by the time I got home LOL
Ford F-150 Lightning Did OTA 10.3.0 Remove Charging Locations? 1738115339220-nl
Ford F-150 Lightning Did OTA 10.3.0 Remove Charging Locations? 1738115599253-x5
10.3.0?
I have automatic updates turned on and last update received was in November 2024??
10.1.1???
How do we force an update??
You can't force an update. And 10.3.0 was paused because it caused issues with charging locations.
Some users get updates before the general public as beta testers. In this case, a problem was contained before it got to everybody.
10.3.0?
10.1.1???
You've been with us nearly a year, haven't you figured out that we have ZERO control over what the "FORD' shall desire we receive?!?! Pull up a seat on the second stringer bench and wait for beta testing to finish, BTW, if you look at the 10.3.0 update thread ..... it's PAUSED because of a bug!
MJB28
DE
2022 F150 Lightning, 2020 Harley Livewire
Just changed my vote to yes.
I haven’t charged since the update but when I plugged in today I noticed it’s charging to 100% and it lost locations.
Have you tried to add a location back?
