FordConvert
I swear I saw an option somewhere to enable heated steering wheel full-hot. Was that on gen 13? I don't see it on the spreadsheet.
Should be under Settings > Vehicle Settings > WindowsSpreadsheet shows an option to change the APIM to enable Global Open/Close in Sync 4. Did that but can't find the setting in Sync 4. Anyone know where that setting would be?
Here's what I bought:https://www.4dtech.com/f150-2021-start-stop-eliminator/Hi All,
Just got my '21 Raptor a few days ago. I've started to change some things around Forscan.
Here is what I can confirm works the same as the spreadsheet:
1. Double Horn Honk.
2. Fogs on when high beams on.
3. 726-38-01 xxxx xxxx **-- DRL_IncludeParklamps_Cfg: 00=Disable 01=Enable turns the 5 marker lights on when the DRL's are on.
Here is what I can confirm DOES NOT WORK the same as the spreadsheet:
1. Auto Start/Stop Disabled
Can anyone help with the auto start/stop disable? That's the sole reason I got Forscan and I really want to get it disabled ASAP.
I've seen those, but this can be done with Forscan... I just haven't figured out how!Here's what I bought:https://www.4dtech.com/f150-2021-start-stop-eliminator/
This may not help you any, but disabling it in Forscan will not cause the button light to light up like it does when you manually turn it off. However, when you're sitting at a standstill, you should still see the icon on your gauge cluster that indicates that it's disabled (it's the (A) icon with a slash through it)Hi All,
I appreciate the input. Unfortunately, when using the programming found in the spreadsheet, my truck does not recognize that a steering event is occurring. As it does not recognize that a steering event is occurring, the Auto start/stop works as if I hadn't done any programming at all.This may not help you any, but disabling it in Forscan will not cause the button light to light up like it does when you manually turn it off. However, when you're sitting at a standstill, you should still see the icon on your gauge cluster that indicates that it's disabled (it's the (A) icon with a slash through it)
yep, works.Can someone please confirm that the OBDLink MX+ will work with the 2021+? I would rather get the Bluetooth version for simplicity. Thanks!
I'm not sure whether the Raptor has the same capabilities on active park or not but I have "0B" on my platinum in the address above if you want to experiment.@Livnitup i have a 2021 Raptor and it seems we are missing the active park assist software screen. Is there any way to add it in the apim?
Edit: I see Parking Assistance (PA),
but not sure if that is the correct one to be playing around with
7D0-08-01 xxxx xx** xx--
Have you been able to program these yet? I have a 21stx. I bought an 8" cluster for it. I've programmed everything into it except the mileage. Engine hours, and all other options write just fine to the cluster.No, nothing found for that on the 8" cluster
