jordandev
heavy duty payload packagehow!??
How does that thing ride with 48psi in the tires?Just got mine in: xlt 3.5 eco Screw 4x4 max tow hdpp 6.5 bed 301A tow mirrors moonroof
I’d be interested to see the full spec sheet. I have max tow, moonroof, XLT on mine as well but about 1,000 lbs payload less than this.heavy duty payload package
I’ve got max tow, moonroof, XLT and am at 1691.I’d be interested to see the full spec sheet. I have max tow, moonroof, XLT on mine as well but about 1,000 lbs payload less than this.
Payload = GVWR - curb weight2021 XLT Sport Supercrew 3.5EB 4x4 short bed.
10-speed, 3.55 locker
Max tow Package.
Came with 275/65/18 tires but I swapped them for Ford 275/60/18 wheels. Does this affect payload?
Very limited in what you can get the HDPP with. It's 301A or lower, and I know there are a few other restrictions with it as well.I ordered a '22 Hybrid Lariat but didn't see a HDPP option. Is it only available with certain engines?
The max tow does seem to reduce payload but impact varies depending on the spec. Ex: the Powerboost already has the 3/4 float axle, so really only adds the larger rear brakes. I think its a ~20lb-50lb hit from what I can tell in this thread depending on spec.Looking to order a Lariat EB 3.5 4x4 SuperCrew. Really wanted a PB but the payload just doesn't seem to be there for my needs.
Has anyone been able to identify the difference in payload capacity, if any, of the Tow Package vs Max Tow Package? After reviewing all of the stickers it appears the tow package may increase payload due to the lighter axle...?
Impressive! Can you share the window sticker for spec?Max tow long bed XLT crew cab. Beats a base f250 for towing and cargo capacity.![]()
