MountainAlive
- Apr 18, 2024
- Massachusetts, USA
- 2023 F-150 Lighting ER 512A Max Tow
So I decided to buy a service manual for the Lightning from factory-manuals.com and I'll say it's pretty comprehensive. They ask for your VIN and it's embedded in the file so I'm not at liberty to share any parts of it. However, when I was looking at the procedure to replace a high voltage battery module, I saw something that caught my attention that I hadn't seen reported in this forum yet.
Apparently in late 2023 they made a couple updates to the battery. On one of the pages it noted:
NOTE: High voltage battery trays built from 11-August-2023 are equipped with vent valves on the high voltage battery tray.
NOTE: High voltage battery trays built from 09-June-2023 are equipped with heat shields under the cold plates.
The vent valves are located at the back of the battery pack and there are four of them. I can't tell if this is a replacement for the side vent or in addition to that. But still, it's at least interesting. I wonder what the pros/cons are of this update.
