23 platinum not spraying washer fluid
Patrick
2023 f150
federal government
My truck isn’t spraying washer fluid. I can hear the pump and a very small dribble coming from passenger side sprayer…. Using -40 fluid as well……. Suggestions?
Could be that the pump failed in the washer fluid bottle.
Could be a few things.
-frozen(washer fluid, even - 40 doesn't melt ice that quickly if there was water in it previously.)
-kinked, disconnected or broken line
-bad pump
-contaminated washer fluid that has fine bits of plastic in it that clogs the tiny nozzles.
F-150s, including the Lightning, have had an issue with freezing for over a decade. The issue is with the valve that connects splits to the right and left washer, it freezes, regardless of fluid use. The solution is to remove it, drill it out, and put it back in.
You can verify it is the issue by removing it, then hitting the wash button, and watching the fluid spray out the end of the hose.
Crafty
Lane
Northern VA
2023 Lightning Plat
I had the same exact problem dribble of washer fluid on both sides a month or so ago took it to dealership replaced pump in an hour (they had it in stock) Also have 2023Platinum
