sealingandbolting
- First Name
- David Reeves
- Jul 19, 2022
- Concord CA
- Tesla, RAV$ 4 Plug in
- Occupation
- Engineer
Neither Ford or SunRun (after 8 calls) can answer the technical questions about how the Lighting can actually be used to power the house, questions like does it have a transfer switch (needed to isolate the backup power from the power company) (yes), does it generate a sine ware and can it be used with an existing PV system (both answers are not clear). Here is what I have found. Per the Ford spec sheet the Home Integration System they are advertising is actually made by Delta Electronics, Freemont CA, 877-440-5851, https://www.delta-americas.com/en-US/index. The truck is limited to supplying about 80 amps, or 9.6 KWH, assuming the E10_BDI is used. Ford's marketing information is based on using 30 KWH per day. The average home without air-conditioning, swimming pools or other major electrical appliances uses 15 to 25 KWH per day. If you have a 200 map main panel, legally the electrical codes will likely require that a sub panel be installed with just the lights and plugs that will match the inverter output capacity. You can't use an 80 amp power source to power a 200 amp rated panel. Given the cost involved of the inverter and installation (starting around $9,600), you might be better off getting a whole house generator that runs on natural gas (around $10,000 to $20,000 installed), then you can power your entire house and charge your truck regardless of weather conditions or the length of time the utility power is out.
